finally a free energy from convergence of all type of incame......
Started by hammuraby, April 11, 2009, 12:15:39 PM
Cap-Z-ro
Speaking personally hammuraby, due to lack of technical background I would need some some description on the function of the various components shown in the pictures before I can understand how they function.
Regards...
hammuraby
ok, i try to explane better,
if you had see a pictura , in the first part (on 3) there is a usual source of renowable:
fhotovoltaic ELETTRIC DC
wind gen  ELETTRIC DC or mechanic "air compressor"
sea wave gen , as pomp compressor
BECAUSE at FIRST part (of picture) is a necessity chose into what  energetic vector turn the renowable energy incame (waiting the termich in second part)
or whit Dc pump water from bottom of sink to surface (to therd part)
or whit DC motor generate a air compressed (to second part )
or meccanich into air compressed (to second part)
SECOND part a treathment whit thermic of air compressed:
if i have a motor in DC and generator DC, that reach a 95% of efficence, the lose is about 10% ( like a expansion of AIR at  DT 28C°)
( 95% x 95% ) + (28C° x 3.7%o) = 100% ; (DT > 28C° = Over Unity)
THIS delta, 28C° DT (between incaming air , and out caming air )
can be reach whit a natural source of heat, easily in summer
but, also in winter , because winter is a natural source of cold air , and using a geothermic can done a suffly DT.....then endless....
and can be possible to put in a cicle Brayton (or External Fired Gas Turbine) all recicled low heat outcaming from umanity-activity
motor cooling (gen) , fired waste, or, iron roof collector....
in the THERD  part or:
the DC came directly (from first part) ,
or from (second part) a conversion in OU throught air compressed-heat conversion
TO a DC water pump, that rise the water from the bottom of sink to the surface water-pool
(unlookable, because refilled whit fired-brik)....make a BIG accumulator.... made sure that you can use also a RAIN collection from...(will be bigger)
THIS way is back on the MICROGRID wire , and then all in DC...
when the necessity call energy the water will bw turbined whit a descharge from surface to the bottom  of sink, and GIVE on the same wire a energy in AC.
kind regards MIRCO SANGALLI milan
hammuraby
here a picture that i ask a hand for e develope
everywere urban system
