AC Permenent Magnet Motor
Started by gotoluc, April 12, 2009, 04:41:35 PM
jadaro2600
AC is indeed different from square waves.
I assume he has the coils setup to oppose one another? ..to pulse in opposite directions as the rotor spins?
wings
Michelinho
Hi gotoluc,
Interesting video and I did something similar with my Newman motor V 1.0 driving it with my signal generator using square and sine waves last year. I did not have a ammeter connected so it went by as an interesting experiment.
I think that as you increase the load, the magnets does not create as strong a CEMF and the load diminish. Same as when you load the generator with the light but the speed drops faster and the rotor bucks to a stall. Same problem as you increase speed the CEMF makes the rotor lose sync.
Thanks for lighting one more cell in my poor brain.
Keep up the good work.
Michel
gotoluc
Quote from: jadaro2600 on April 13, 2009, 03:04:15 AM
Hi jadaro2600,
thanks for looking at this topic :) Can you explain more on your statement "AC is indeed different from square waves" because my understanding AC is square wave, triangle wave or sine wave. If a wave form is alternating polarities at every pulse I though this was AC. I would not want to make a mistake and I'm open to learning.
The coils are not setup to oppose one another. They are both in the same direction and connected in series in the 2 last tests of the video.
Luc
This is very interesting indeed.
I think the key to this motor is tuning it to the load like you said. When you load it you have to make sure the load does not have a bigger torque than your motor. If you can fine tune the load just where it almost equals your motor torque I then believe this spot will give you the lowest input current and highest efficiency results. Loading the motor any more will bring it to a halt like you have seen.
Also how does the motor do on higher frequencies than you just have shown?
