Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
Tommey Reed
I agree with the higher voltage, but the time to built up at higher discharge will take longer then at lower volts. Trying to spark at a higher frequency will also need more power input. Say if you had to run a engine at 800 rpm's 13.3 times a second would be needed.
Tom.
Tommey Reed
I have my patented tested combustion chamber that use any fuels, I use it for hydrogen combustion tester. I would need about 30 second time charge from the electrolysis to fire, but this would take 12v 10amps of power.
I think a type of energy like a atom smasher at low power could split the water into hydrogen and oxygen and even cause a combution to happen at the same time.
I also think, if you could inclose this type of energy in a coil that this explosion will transfer this energy in to electrical energy.
Like a dirty EMP bomb, that use explosion in a wired field to convert in to EMP pulse.
Just a thought....
Tom
powercat
2 from Tommey
videos has been removed by the user
cat
