New Wheel Design
Started by Alexioco, April 16, 2009, 07:52:51 PM
AB Hammer
Quote from: AquariuZ on April 21, 2009, 08:45:10 PM
Wow, just wow.
Corporate is moving in. This is why you concentrate the floating on forums. Control the flow...
Don´t make me create my own forum now... Unbelievable patterns are forming in here... I must start a file on suspicious communications between "members". Yes I am implying unshielded opposing forces. Prove me wrong.
FDROLMAO AquariuZ
A Blacksmith and a construction worker  Corporate?  FDEOLMAO
The only difference is what can protect the inventors name and possibly a carrier of inventing. Or give it away and work for those who took it from you, just a little above minimum wages. It is your choice.
Alex
If it works, do the cover thing until patent pending is in place, then shout it from the mountain tops.
Show it self starting and accelerating, but not how it truly is and that should be enough for the string. IMHO
Alan
AquariuZ
Quote from: AB Hammer on April 21, 2009, 10:45:40 PM
FDROLMAO AquariuZ
NO! You're a shape shifting corporate lizard alien who has replaced the real AB Hammer!  :o :o :o
OK, I may have overreacted a little.
Self portrait attached. Tihi  ;D
Alex, please do not leave us hanging like in the MT Combination thread
Pretty please
AZ
AB Hammer
Quote from: AquariuZ on April 22, 2009, 07:17:19 AM
Pretty please
AZ
AquariuZ
386?, dot matrix? That is a very old photo. LOL
Alan
Alexioco
Well, today is the day, I'm about to put it all together...
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Low-Q
Quote from: Alexioco on April 17, 2009, 04:32:17 PM
I dont agree because though gravity is constant, weights that move in and out of an axle are not, a weight with gravity equals force and that force can be made greater or lesser depending on the position of the weight to the axle of rotation...
Wind is dynamic but even if it wasnt, it could still turn a wheel due to the blades, so that same effect needs to be applied to gravity so that its pull is stronger on one side of a wheel than another but this time, not by blades, but by weights...
Alex
You can alter the torque by moving the weights in and out, but you have to consider the time you have the different torque levels. Energy is torque times time - not torque alone. You will anyway in one revolution lift the weights up as much as they fall down. Those operations respectively require and release the very same energy. Whether the object is moving sideways toward or away from the center doesn't make any difference. It is the UP and DOWN operation of mass that matters. Therefor it is impossible to make a gravity powered motor. I'll bet my balls that you will never make those work.
Vidar
