New Wheel Design
Started by Alexioco, April 16, 2009, 07:52:51 PM
Alexioco
Quote from: AquariuZ on April 22, 2009, 11:50:27 AM
A model would be handy (hint hint)
AZ
lol I bet... I found that not all of the levers need cutting, firstly, I'm going to look at the levers, cut them to how they need to be cut, makesure they can lean on the axle if not, then I will need a thicker axle, so in the mean time, could somone tell me what I can use to make the axle even thicker, I dont want it to thick or its defeating the object of the weights going in to make an overbalance...
Yes, I model test would be great, I would appreciate that very much, but I dont want to reveal this untill I have tested it if you dont mind, then the model test can be compared to my real life test...
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
overtaker
What size is your axle now and how much larger do you want to make it?
4Tesla
Quote from: overtaker on April 22, 2009, 06:36:18 PM
You'll find out tomorrow  ;D  ;)
Alexioco
The axle is now 2cm thick, I need it to be about 4cm thick.
Alex
overtaker
Buy a short piece of pipe 4cm. thick  ( the length you need ) and measure the inside diameter of that pipe.  Take that figure and subtract 2cm.    Take that number and divide by 2.   Now just buy some dowels that size and install several pieces between the pipe and shaft.  I hope this helps.
