What if you could have a unipolar magnet?
Started by AquariuZ, April 21, 2009, 08:53:28 PM
Low-Q
Quote from: AquariuZ on April 22, 2009, 11:56:09 AM
Nice. But even though it may encounter BS I do not think it is BS.  ;D
I'm sure you saw the patent right? Easy enough tested if you have a flux meter...
Look at the flux lines. There is four loops. One pole at the ends and the other pole in the middle. There is a magnetic closed loop, so this is just a doubble regular magnet. One magnet in each end where the same pole is facing outwards. The poles pointing towards eachother in the middle force the fluxlines to excape out to the sides and close the flux loop at each ends. Looks like it on one of the drawings anyway. So this is most probably no monopole, but a doubble dipole. Not very common, but not rare either.
Vidar.
gravityblock
According to wikipedia:
"Magnetic pole model: Although for many purposes it is convenient to think of a magnet as having distinct north and south magnetic poles, the concept of poles should not be taken literally: it is merely a way of referring to the two different ends of a magnet. The magnet does not have distinct "north" or "south" particles on opposing sides."  http://en.wikipedia.org/wiki/Magnet
I think a common magnet is already a monopole.  There are no distinct north and south poles as wikipedia suggested.  You have a force that is both leaving and returning to the magnet.  The same force that leaves the magnet, will also return to the magnet.  We refer to the south and north poles in order to distinguish between the force leaving or returning to and from the magnet.  This force has the same properties when it is moving away from the magnet as it does when it is returning to the magnet.
There is only one thing that makes this force return to the magnet, and that is the aether moving in an orbital path due to the electrons moving in an orbital path with their spins aligned inside the magnet.  Electrons moving cause the aether to move.  Likewise, when you move the aether, it will move the electrons.  Physics recognize this aether as virtual particles and is also known as the magnetic field of flux. Anytime you follow the same orbital path, you will always return and leave from any point along that orbital path.
There is no need to complicate this more than it needs to be.
hansvonlieven
Quote from: AquariuZ on April 21, 2009, 09:20:24 PM
I cannot keep a secret anyway
US Patent 7289011 Oct. 30m 2007 ANIMAL MAGNET PILLS HAVING SINGLE POLARITY (Attached)
A patent which contains an improved version of an animal magnet to battle "hardware disease"
The magnets have a selectable single polarity.
You can order them right here: http://www.animalsupplyintl.com/sheep_goat_products.html
Ships in boxes of 25 pcs.
Now scoot along and build your engines. Forget shielding, just use these... (no not in there!)
I know I am... How about a dual cylinder, outside static north polarity, inside rotor with angled south polarity.
Zoooom.
Henry Ford's famous COW MAGNET, you know the one he said you could run an early T-model Ford with, wihout petrol !
Hans von Lieven
AquariuZ
Quote from: hansvonlieven on April 23, 2009, 01:44:59 AM
Hans von Lieven
See, there is life in overunity.com after all.
Very good Hans.
