Cold Electricity
Started by gravityblock, April 30, 2009, 01:11:26 AM
ramset
Grumpy
Are you serious?
I mean your not just pickin on me?Isn't that a little tricky??
I have company today but I will look Tonight!
Chet
Thanks Grandma
sigma16
Quote from: ramset on September 11, 2010, 06:33:06 PM
Grumpy
Are you serious?
Chet
Yep.  Serious.  Talkin' is talkin' and walkin' is walkin'.
ramset
Grumpy,
I must be candid,I do believe absolutely you are capable of doing this,I have zero doubt.
However this is beyond my present skill level,I am quite sure that I could understand what is going on there [seeing as how I've been attending OU school regularly].
But I believe for "me" right now that this
http://www.overunity.com/index.php?topic=9690.msg256688#new
http://www.overunity.com/index.php?topic=9448.msg256712#new
would be easier to "harvest" from and holds less
political BS and could be done with some of the coil designs you fellahs have been playing with.
No disassocciation of pure water [scary shit].
get the Gas without the scary stuff!
And the "harvest" is the gas!
Unless you feel It would be easier to "harvest" the SM way ?
This only you would know!
This world needs something NOW!!
Chet
Thanks Grandma
Magneticitist
i think negative electricity or cold electricity is nothing more than the utilization of super high voltages to run low voltage loads.
electricity is only considered "hot" when current is introduced.. we all know electrostatic charge carries no heat.
the use of a spark gap helps us tune this cold electricity, but in the end its just compressed voltage i believe. the only way to light a filament bulb and not have it get hot is to light it dimly with a spark gap.. far as i know..compressed voltage.. otherwise u are introducing current and no matter what that current will expel heat.
if it's negative voltages were talking about there are a number of ways to get a meter to read negative voltage. it would also seem using this idea of "negative charge" would mean simply charging a capacitor backwards would make it use negative flow.
if current is naturally alternating, and alternates always, even in DC (back emf) then why would current flow even matter. at that point we are talking a linear direction of motion similar to reversing the polarity on a motor making it spin the other way. the actual characteristics of the electricity does not change tho.
i need more info on this cold electricity and how to "use" it other than running loads from a spark gapped tesla coil
WilbyInebriated
Quote from: Magneticitist on September 12, 2010, 09:46:19 AM
there is no spark gap in this...
http://www.overunity.com/index.php?topic=6123.msg218520#msg218520
