Cold Electricity
Started by gravityblock, April 30, 2009, 01:11:26 AM
0 Members and 170 Guests are viewing this topic.
ramset
Ghost_rider
Quote:
Soon all will have.  ;-)
What do you mean?
Chet
PS
HEY HOLLYWOOD..............
Watcha doin??
Makin movies or buildin stuff??.................
Thanks Grandma
WilbyInebriated
so, i've met one qualification of 'cold electricity'... is that it? or are there others as well?
where are you heavy hitters that know all about CE?? marco? polo? quarky?
are there other qualifications or not? and if yes, what are they? because i've probably met those as well.
gravityblock
Below is a quote from mk1 posted on energeticforum, http://www.energeticforum.com/renewable-energy/7312-electric-field-2.html#post128787
@all
I have to bring this forth because i think it relates here , i have recently learn that i you have make 2 coils one of iron and one of copper exactly the same , if you connect each coil to a battery the same way , the copper coil and iron coil will show opposite polarity .
So this means that the current either flows in opposite direction Or its only the reaction to the current that is opposite .
But after a few days of thinking about it i will speculate that by using copper wire only we are using only half of it , leading to dead a battery ...
The NS coil was bifillar Fe Cu , and showed operating specs really low .
If they are really opposite , they should theoretically cancel each other (not showing on scope ) but the NS coil showed that it worked anyway .
I therefore think all we know of is the electric field and reaction to ferromagnetic , but never even had a chance to look the magnetic current .
I could go on and on but , but a am not sure it will make sense to anyone .
Mark
I think we need to look into this further.
GB
exnihiloest
Quote from: XS-NRG on January 27, 2011, 08:24:38 AM
Give me one good reason.
The goal of this forum, which is dedicated neither to fiction nor to biblical-like speech ("in truth I say to you, my AA battery generates 100 MW thanks to my energy amplifier. No proof. No schematics. Believe me!  :P").
TeslaTolman
Cold electricity is for real! I prefer to call it "cold current" since apparently there is no "electrons" flowing through the output. The electron flow is slower than the cold current charge. So if you hold back the electrons and allow the charge to flow, then you get power without the heat. There are certain characteristics of cold current which gives it an awesome potential! From what I have read and understand is that with cold current, motors run cold and even frost up under a load; the heavier the load, the more the output increases to meet the load until a thresh-hold is met.(By the way, you need to have a load in order to tap the CC effectively.) CC is not over-unity by itself, but should be most appropriate form of energy to use for "free energy devices". I would guess that CC is about 80% more efficient than conventional electricity. Also, light bulbs can be lit with just one wire or none at all! Cold current can be transmitted as well. The light bulbs will be cool to the touch, glow with a more bluish spectrum and brighter! You can also submerge the bulb in a cup of water and put your hand into it without any shock or harm! (Much safer! Just one of many reasons to pursue it further.) Cold current may even have healing properties as well.
Several circuits are readily available for small scale cold currents such as Dr. Stiffler's cold electricity circuit, the Slayer Exciter, and the Joule thief. Of course the great Nikola Tesla first discovered the phenomenon, but since then only a handful of people have made any progress in almost 100 years! EV Gray comes to mind...Also, Peter Lindemann has a book called "Secrets of Cold Electricity" which you should find very
helpful.
Ed Leedskalnin who built Coral Castle explains magnetic current and there are some of his experiments you can try. Very simple but intriguing.
I've created and transmitted cold current by following Tesla's inventions. I took a car battery, an ignition coil, and some circuitry with a spark gap. I made a collector tube and a coil to direct the radiant energy...Then I magnetically quenched the spark gap the high voltage spark gap, as suggested by Tesla. This is a very important key factor as magnetically quenching the spark gap prevents the electron flow and allows just the charge to continue across the gap. Also, this greatly increases the frequency, and thus the energy levels! You must get I believe, 50,000 pulses per second or faster of high voltage DC spikes for the effects. I took an almuminium pie pan and put a wire on it and put it into ONLY the ground of my wall outlet, I then took a cfl and touched it to the pie pan and it lit up! Wireless transmission of cold current!
Hope this helps.
