Latest: No back torque generator.
Started by broli, May 01, 2009, 09:04:43 AM
Oke attached is a diagram that I hope will make things more clear. It's explained using the Lorentz force law which I don't like to use much but since it's a closed loop it doesn't matter. The "catch" as I mentioned earlier is that you have to apply the same idea on the electrons that are spinning to form the strength of the field. But this is not important since we're dealing with a permanent magnet. Try and substitute the magnets by an electro magnet and you'll see what I mean. All you have to do is flip the current conductors 90 degrees if you wanted to replace the PM with an electromagnet.
Again this is why only magnets can be used. Or else as the the voltage is increasing on one pair of conductors it's decreasing at the other and you have gained nothing. While a permanent magnet has a permanent current flow (http://www.energeticforum.com/images/smilies/biggrin.gif).
An additional note: In textbook when induced current starts to flow we see a counter force arising impeding the motion that is inducing the current (in our case the applied rotation). But what these textbook don't talk about is the reaction force. We know it's on the magnets but how exactly can we define it. This is where things start to get very misty as they try to make it look complicated by saying "ah yeah it's in some exchange of momentum and kinetic energy of the magnetic field" w/e that crap means. If you use the old forgotten ampere force law you will see exactly where this reaction force applies to and agrees with newton's third law in the strong form (the weak shouldn't even exist).
Now the point I'm trying to make is. This flowing current will produce a counter torque trying to stop our rotation but that's the beauty of this setup. Because the magnets will experience a reaction torque due to newton's third law. SOOOOO if we attach them both to each other both forces cancel out and we have no lenz effect with free flowing current.
Low-Q
I hope I don't mess up too much, but I have a few questions:
in the latest drawing you show the rotation of the parallell wires. Left is going up, and right are going down, causing a clockwise spin.
The magnetic field is going towards me at the left side and away from me at the right side.
So there should therfor flow electrons in the same way on both sides of the parallell wires.
I assume the magnet are spinning and the wire is fixed.
This will generate AC.
I then wonder why you don't get back emf if you load the wire. It is simply a magnet that is crossing a wire. Pr. definition, all loads will prevent the magnet from generating current flow through the conductor - then force it to slow down.
How can this generator then have no back emf? And why can it not be used as a motor - at least an AC motor?
Vidar
petersone
Hi Low-Q
As I understand it,the coil and mags. are glued together,they rotate together,bit like a Faraday disk,I think.
peter
Quote from: petersone on May 06, 2009, 05:00:27 PM
Hi Low-Q
peter
Yes petersone you got it right. Also more up to date information can be read here:
http://www.energeticforum.com/renewable-energy/4176-latest-no-back-torque-generator.html
petersone
Hi Broli
Thanks,I got something right!! It don't get that very often.
peter
