New Gravity Wheel Design BREAKTHROUGH MODIFICATION!
Started by Yortuk Festrunk, May 01, 2009, 05:56:33 PM
AB Hammer
Yortuk Festrunk
Yes I understand all you have said. But I don't see the travel. But I will await your build.
Alan
Lilhawk
AB Hammer your right about the travel....I did some basic math to this.... the counter weight(red pulleys) need a lot weight
I rounded in Yortuk's favor but at the end you need over 6.5 times of swinging  counter weight to center weight , just to balance this
IMO this will not work and wastes peoples time.
Yortuk Festrunk
Quote from: Lilhawk on May 02, 2009, 03:22:00 PM
You're a funny guy. What part of "THIS IS NOT TO SCALE" do you not understand?
Whatever weight it takes to move the main weight is what the counterweights must weigh. Whatever diameter the counterweight wheels must be to turn the rollers to move the main weight across the main wheel is the diameter they must be.
This picture is to give people the general idea of how this system works. I'm glad you have an opinion on it. Since it is your opinion alone, then it is a waste of YOUR time. There are many people who DON'T think this is a waste of time and are now making their own sims and models because they see that this will work.
I hope you find something better on which to spend your time.
Lilhawk
actually your right this is my opinion....I should not force/tell other people this is a waste time
also I did not prove this wheel will not work. The final math would involve the center weight force minus the counter weights force as per positon on the wheel.  I threw in numbers to show how much of a relationship the force each wheel has to each other and the center weight.
Your right there is probably a perfect counter weight/ counter weight diameter and position.  When this is acheived you will have a balanced wheel that will turn as far as the friction will allow it.
I guess I'm making this a little personal....but when you see "breakthrough" ...I was a little let down
noonespecial
As I mentioned in a previous reply, I did get a similar design to work in Phun(although only temporarily due to Phun's limitations).
The holy grail of gravity wheel design is getting the weight back to the top to restart the process. This seemed to work in my simulation but this is such a simple design, it wouldn't take a lot of effort to throw one together to validate it.
I'd be willing to take a crack at it once my pendulum project is complete.
Charlie
