IST SHIFT COIL
Started by innovation_station, May 17, 2009, 08:40:27 PM
innovation_station
WHAT I BELEAVE TO HAPPEN IN THIS UNIT AS SHOWEN WHEN THE PRIMARY IS
POWERED AND INTRURPTED AT ITS NATURAL RUNNING FREQ..
THE KICK WILL BE FORCED BACK INTO THE DRIVEING CAP CHARGEING HIGHER IN VOLTAGE...
THUSS RUNNING WITH GAIN ...
SO THE FOLOWING DUMP WILL BE OF MUCH HIGHER VOLTAGE..
TO THE PRIMARY AND IF THE CHOKE COIL IS NOT ENOUGH RESISTANCE USE A RELAY COIL ....
IST
jeanna
Have you found its natural running frequency?
I am winding a very big core today. It may be the same size as yours. Its frequency is naturally a lot slower. I expected this, but it is a lot. (17KHz at 1000 ohm base resistance) .  I hope I can get enough voltage from 240 turns to keep the voltage high enough when I up the base resistor to raise the frequency.
I like the plan to snap the cap at the rate of the MK2 pulses. Good idea.
jeanna
innovation_station
TY JEANNA
BUT I DONT WANT A RESISTOR ON IT I DONT THINK ....  NATURAL ....
;D
THE CHOKE DETURMAINS HOW MUCH IT USES ...  ADD MORE AS YOU SEE FIT ... THIS IS 1 TO 1
IT SHOULD BE OR IT COULD BE ...   LOL   369
OR 1 2 3 IF YOU LIKE X THE MASS OF THE PRIMARY ...
IST!
OR YOU COULD GO 3 6 9 X THE LENGTH AS LONG AS THE GAGE IS THE SAME ...
IF I DO PUT A RESISTOR I WILL USE SOMETHING LIKE 1 OHM 5 WAT OR SO TO PORTECT THE TRANSISTOR ..
innovation_station
 FOR THOSE THAT FIND AN INTREST IN MY COILS HERE ARE THE DETAILS...
50" 14 GA 10 T P 24.5 G AND 265 T 28 GA 24.5 G 180 DEG OF SEPERATION
STANDARD MK2 LITZ WIRE PICKUPS...
IST UNPLUGGED ... :)
jeanna
The resistor I refer to is in the MK2 first coil set up as a joule thief.
Then it is collected in a cap then the cap discharges into the one you have there and that discharge is the frequency that has no resistor.
Did I get that right?
jeanna
