Mylow Motor was a fake
Started by hartiberlin, May 20, 2009, 07:43:27 AM
Grr.
Watts, to reply to your point about my fishing line reps: Mylow's motor has a shaft that's about the size of my thumb if not larger. No flanged drum or pulley is needed, just a little angle on the line running off the shaft so it doesn't work its way up and off. I am actually rather surprised at how well the line system tracks without taking special trouble. It's no problem for the system to work on that large  motor shaft.
Also as I have shown the line does not have to be very taut, and this helps with the clutch effect--and remember that the wheel is quite heavy and will most likely be slipping the clutch during acceleration and deceleration.
IF mylow was sharp enough to include an adjustable idler wheel -- or a chair leg -- he could have varied the tension to make the clutch effect less or greater. I know this because I have done it. In addition I have shown how the line could run around a shallow corner without problem, and I know how to make it turn a steeper angle without hanging up as well. So with a few paper towel roll tubes some duct tape and some chairs, (and some strong magnifying glasses !!) I could run the line around 90 degree corners and up the stairs if I wanted to.
So please believe this and don't make me demonstrate it to make you believe. You are skeptical, and that's good, but about some of the wrong things sometimes.
The point about putting the line down and then picking it up again without it falling off is a good one, and with old monofilament that is stiff it probably would, but this new tech monofil line is sooo limp, it reminds me of...well, never mind what it reminds me of. Let's just say it is pretty limp. So if one kept the loose end relatively under control, like having a projection to loop it around or a sticky piece of double-stick tape to stick it on, there would be no danger of it slipping off the shaft while Mylow was handling the other end.
Again, I know this because I've tried it. It's not hard.
OK, that's all. Watts, the public vote so far, as far as I can see was only one vote against you. We almost all seem to want you. So for goodness sakes lighten up, man!
:P
nyctuber
Question...
Say Mylow had an overunity device which operated at 200% efficiency
And he decided to use it's output to power itself.
It would then increase it's output (if tapped for output) exponentially, right?
Would this not be an extremely dangerous device?
Would this not make the idea of overunity dangerous?
RunningBare
Well, mechanically it would reach a limit, friction increases with speed, so you have bearing friction and air friction, if it increased exponentially indefinitely then mechanically something is going to give, my bet is on the glued magnets shooting across the room.
Edit to add
If and I stress if someone does come up with a motor that can produce such results, then it's just a case of adding a braking/clutch system to stop it from increasing to dangerous speeds.
Quote from: nyctuber on May 20, 2009, 03:21:09 PM
Question...
nyctuber
Quote from: RunningBare on May 20, 2009, 03:48:15 PM
I caught a 'desertphile' video rant, something about E=MC2 causing a self-powered device to become exponentially heavier and eventually sink to the center of the Earth. I know machines normally have physical limits as you point out, but it's an odd thought.
AquariuZ
Quote from: wattsup on May 20, 2009, 11:17:04 AM
@Stefan
Sorry but your are wrong to say this is ALL a fake. We have the first wheel and we have people that have attempted to subvert the main thread.
On example:
@lostcauses10x
Posts:    133 (2.078 per day)
Age:    N/A
Date Registered:     March 16, 2009, 04:49:01 PM
Last Active:            May 19, 2009, 11:59:41 PM
Local Time:            May 20, 2009, 01:55:12 AM
Wow in only two months days you posted 133 posts and you had registered here on March 16th, 2009. Busy guy hey. What was the rush in all your postings buddy.
Actually let's see one more:
@nyctuber
Posts:     404 (7.481 per day)
Age:    N/A
Date Registered:     March 27, 2009, 06:54:08 AM
Last Active:
Local Time:    May 20, 2009, 02:00:00 AM
Wow again and a real busy guy comes here on March 27th 2009 and manages to post 404 f(*&?n times, almost all on these Mylow threads. To say what????????? F*&k all. Just junk, diversions, and pure crap.
These are some of the members that were allowed to be present in this disclosure thread. Very dangerous and very unprofessional people that were allowed to spew venim any time other members started asking questions about the wheel.
So @stefan, you as operator of this now defiled web site have a choice to make. Give yourself the one level of criteria we used when you banned @Humbugger for not even 10% of what many members here got away with on this thread. Subversion, intended or not I don't care.
We had the intitial opportunity with Mylow when he was showing his first wheel but we never got the real chance. We all knew Mylow was ready this thread but members were left free to massacre him in public,
Conslusion of all this is overnutiy.com is not the place for disclosures if it does not have a totally protect area and if only members that are known non-subverts to participate. If it does not happen here then I will make a place for disclosures to be done in total security from the likes of total jackasses. Once the disclosure is made, then it can me made and given to the public to comment at large. Once we have it in hand SOLID.
The real OU members could have done all this Mylow business, fake or not, without yelling out once and we would have probably gotten much more real information. But there was never a chance.
Shit. All I wanted to do was talk magnets, wheel, feel and all these guys did was kill the guy and piss him off to the point of either orchestrating the last stringies or was compelled to do so, or we are just being tricked again.
Funny how an overunity.com forum member can take so much pleasure in all this mahem. I am ashamed to be on this forum.
I will ask all members including the silent majority who agrees with me to send @stefan a PM, only one each, stating only one sentence "I WANT MY OVERUNITY.COM FORUM BACK".
Or if you do not agree with me, send him a PM stating "PLEASE BAN WATTSUP". Then whatever the majority will say, I will be ready to leave this forum for good. lol
Wattsup, you are the MAN. I was afraid to post the obvious, but now YOU have.
You are real. Actually real in a world of masks.
If I were a woman I´d propose to you.
O, wait, maybe you ARE a woman? Drinks? Pick you up around eight?
:D
Seriously, your post made my month.
AZ
