Mylow Motor was a fake
Started by hartiberlin, May 20, 2009, 07:43:27 AM
Hmmm...Wattsup has pointed out some places where Mylow might have moved the stator mount further than seems compatible with having the "PS" come through the hole and stay wrapped on a motor shaft. And I can't really see a string in the screenshots that people have posted (I still think I see it in certain places that I have mentioned, even moving).
But--here's another thing to add to the mix--when I was setting up for the last vid, I noticed that you don't really even need the motor. By cleverly manipulating the free loop with Mr. Hand I can make the rotor spin quite nicely.
And of course we can not rule out the assistance of a confederate--Tony is already implicated, despite his denials, by his participation in the obvious YinYang vid fakery, so he could easily have been off screen helping out.
Regardless of which of these clues and cues turn out to be correct, even if something different shows up, it is still impossible for Mylow's motor to have worked by the action of its magnets. Impossible. So any other explanation that IS possible is to be preferred.
To reuse an example: If someone told you that he could leap off the top of a tall building, float gently to the ground and land in front of you dressed only in a t-shirt and skivvies, without spilling his decaf latte, and then proceeded to do it---you'd be looking for wires too. Even though everybody knows Superman did it.
The point is, when someone shows you something that is clearly impossible and contradicts what is known, you have to keep looking for fakery until you find it, because it certainly is there.
It's that "contradicts" part that's the rub here. Two contradictory things cannot both be true. Mylow's motor isn't just hard to make or tricky or "new physics", it is flat out contradictory to a lot of consistent and well-behaved science. So it simply cannot be true. Look for the strings (or other fakery method), they are there somewhere even if you can't see them, because anything otherwise would be contradictory to what we know to be true.
ellubpt
I am curious about the video where he pans around the room. Showing the bed and the computer. It looks like there could be something under the pillow on the bed and in this particular video the stator is on that side. However, I do not have a hi res copy and with limited tools, contrast, light,saturation and zoom effects...I cannot detect anything. In this particular video video, he enters the room with the camera in hand and never touches the motor.
I wonder he has spun prior to filming and it is spinning down?
A speed analysis could tell if it is slowing down. Anybody do one on that video? I believe he had "still running" in the title. Anyway, here is a screen shot to the left with the stereo on the table- no motor there.
Pirate88179
I agree.  After seeing the motor on the couch I always wondered about that bed.  Do we have any clear shots of the right side of the device in video 6? (The last one in "question")  The photo blow-ups I posted were all of the left side as that was where he had the lines in the glass table video.  Interesting you point out that the stator was on the right side in this video.....hmmm.......maybe he used the bed all the time and that gave him the idea later for the couch for the glass table video?  They both are about the same height and they both have pillows.........good thinking here.
Bill
Please do not forget that I have demonstrated that the Mylow drive can be easily routed around corners, etc.
ellubpt
Here's the bed shot with pillows and shot of the motor running with the stator mounted to the right. I wish we had a timed rundown on this video.
