The Perfect Spacecraft
Started by onthecuttingedge2005, June 10, 2009, 01:23:40 AM
I don't feel comfortable with this thread so I am signing off on it.
I'll see you around the forum now and then when there is something interesting going on. it is way to deep for me.
triffid
While solar sailing is still what I consider to be the cheapest(not the shortest way) to get around our solar system.I found some kind of space drive based on generating radio waves.Check out the following website.http://www.crossfirefusion.com/spacedrive-electric-propulsion/electrodynamic-space-thruster.html    triffid
Eleusis
I had a book once (that has long since been misplaced) that discusses a Propulsion System of Space Travelers.  That it names the Omicron Nucleus....  I have also come into contact with some people from JPL that spoke to me about a device known as Tachyon Drive that can get from one end of the Universe to the other, before it leaves....  they have remarkable similarities.....
with the Omicron Nucleus, there are 4 Hollow Copper Rings filled with Mercury.  If you take a Bunsen Burner Flame and rotate under each Ring....  the Mercury will revolve 4-10 times in the opposite direction....  (I forget how many)
once you have the Mercury revolving, and you remove the Flames, you replace it with an opposing Magnetic Force and it creates a Dynamo
which is basically a fluid armature.....  it would create enough power to drive itself
