AC from Joule Thief Secondary/pick-up
Started by jeanna, June 16, 2009, 03:11:33 PM
jeanna
Wow,
This is really cool.
I was filming my last video part 4 in the series to help people understand this circuit when...
I changed the inductor on the 10 leds in series from a 220uH to a 1.39mH inductor.
Now, everything goes without a struggle. Of course it took all day to realize it, but in the end I can now light 2 groups of 3 leds in series from the 21 turn S2 to the same brightness as the 10 leds in series from the 84 turn S1.
Oh good.
Here is a drawing, because I think it is easier to follow than all my words.
If you want any explanation, please ask.
thank you,
jeanna
Edit
I can see now how I can straighten out the lines of the S2 circuit.
I will leave that for another time.
j
jeanna
Hi everybody,
This needs a new pic.
I added 2 more leds to the 10 which have 1.39mH inductor.  These are on the S1 secondary.
I noticed when I used a supercap in place of the battery no matter what else I did, the 10 leds I had there stayed on for longer than the 6 on the S2. You can see this  in that last video I made.
I was adding caps to the S2 secondary, and I was getting different effects, but as I say, no matter what I did, those 10 lingered on longer than the lights on the S2.
In the meantime, I kept adding small but bigger and bigger caps across the 220uH inductors on the S2.
Remember, each of these 220uH inductors were running 3 leds.
69pF helped and 220pF helped and took a while to load up the light and finally I added 560pF. But even then that bunch of 10 leds lingered when the cap started to run down.
So, I added 1 then 2 leds to the 10 making 12leds on S1.
Now, they all (all 18)  go on and off together.
To me this means I am not throwing away any useful volts.
And, this is the first time I have even gotten close to the right cap for the job. All other times the cap did nothing.
It is almost as though those 10 leds were absorbing the effects.
I will make a drawing then add more lights until it gets uneven again.
the brightness is unchanged so far.
jeanna
edit
Here is the new drawing. As usual, I made the new parts red.
I saw something odd as I took the data.
The S1 volts went up but frequency remained 111KHz where
the S2 volts stayed the same but the frequency went down to 133KHz.
kooler
i see ya got a super cap in there
will this one work  http://www.goldmine-elec-products.com/prodinfo.asp?number=G17241
i just kidding.. i know its to big... haha ...
Pirate88179
Quote from: kooler on September 16, 2009, 10:46:17 PM
That link is to a supercap of 3 farad and Jeanna is using (I believe) a super cap of 650 Farad. (It is like the one I use)
kooler
i know on my air coil jt's if i go to big on the cap on the bat side it stops working
crazy ... huh...
