0 Members and 153 Guests are viewing this topic.
powercat
Quote from: TinselKoala on August 10, 2009, 01:46:43 PM
Hee hee. Yersss, Cat,  and if you should happen to manage to accidentally short-circuit that very large capacitor, you will find out what very low internal resistance really means. Ever drop a wrench across a car battery? Imagine that, times about a tenth of the battery's output impedance.
It's a good idea, just be careful with capacitors, they will eventually bite you and they do bite hard.
Thank's for the warning Tk
as I live on a boat with no shore power. I have spent a long time on batteries
and tested them with a drop tester many times when they were old
anyway it's always good to give a warning we don't want those ambulance chasing lawyers after us
cat
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
AC:
Your comments about capacitors are true.  I am always thinking in terms of the KISS principle in that for my specific "simulated battery" example the ESR and other properties can be ignored when working with a typical Bedini motor or other typical experimenter setup on a bench.
Rosemary:
QuoteI have no idea what the actual rms voltage is across the load
I am going to assume that you are interested in the RMS voltage across the load to calculate the power being dissipated.  The "load" of course is the "coil-resistor."  How many times Rosemary do you have to be told that you can't use RMS voltage, and the power dissipated across the coil-resistor is voltage AND waveform/frequency dependent?  We must have tried to get this fundamental concept through to you at least 50 times, and it still doesn't stick and you are apparently back at square one.
Quoteit's 10 volts, then that's hardly enough to boil water, assuming that the load is 10 Ohm
You don't understand how thermal systems work.  Plus you are making a subjective call with nothing to back it up, you are learning from Aaron.  If not 10 volts, then how many volts?  12?  15?  27.5?  You have no clue.  The real answer is that for a 10-ohm load, any DC voltage could boil water as long as the thermal resistance to the outside world is high enough.
QuoteI would love to see the dc average across the shunt from the Fluke 123 at a duty cycle of 3% and with the required oscillation.
If you understood what I said above then you would conclude that the DC average is irrelevant, garbage data. <CORRECTION:  I was thinking of the DC average across the coil-resistor, and not the shunt resistor.  The DC average across the shunt resistor is relevant.  However, like for any measuring device, the Fluke DC averaging measurement is bandwidth limited, and will fail to measure and average any high-frequency current waveform components above a certain frequency.  My apologies.>
qiman
from Rosemary:
May I say that your video does not attempt any power analysis. I have no idea what the actual rms voltage is across the load and - if you're suggesting that it's 10 volts, then that's hardly enough to boil water, assuming that the load is 10 Ohm.
Also, the waveform you are presenting does not describe our own. You may want to see a description of this in post 1891 - for Harvey.
And yes, I would love to see the dc average across the shunt from the Fluke 123 at a duty cycle of 3% and with the required oscillation.
MH - I do not need a lecture from you. I'm trying to get answers from TK.
