fuzzytomcat
Quote from: poynt99 on September 25, 2009, 09:45:18 PM
Rose asked about the resistor I'll be using:
Length=165mm, Diameter=20mm
No. of turns=64 (2mm spacing)
R=10.1 Ohms, Inductance=29uH (will confirm with a better meter)
.99
http://i1004.photobucket.com/albums/af166/poynt99/Resistor/resistor001.jpg
http://i1004.photobucket.com/albums/af166/poynt99/Resistor/resistor002.jpg
Hi .99
Those simulated wave forms across the 10 ohm prototype "Quantum" resistor are fairly close to the Fluke 123 ScopeMeter wave form. I didn't have a uH meter and left the resistor with Aaron to possibly do a replication of the replication using my prototype, as of now I'm in the process of making myself a new resistor just like the first for new testing with my Tektronix 2445A oscilloscope. Maybe I can or Aaron find out what the resistor uH is actually. We are also planning to make some other resistors possibly depending on if the original documentation on the resistor is all valid, there has been some question on a slight possibly of larger AWG wire being actually used ....
I see you have Groundloops PCB which circuit are you planning to do first the "Rosemary Ainslie COP>17 Heater Circuit"
http://www.energeticforum.com/67700-post2625.html
or the "Ainslie - Murakami Negitive Dominant Waveform Generator Circuit" which is not the same
http://www.energeticforum.com/67702-post2627.html ?
Are you going to use the PCB mounted 10-turn Potentiometer's or use some "Vishay Spectrol" - SP534 Percision Potentiometer/ 10-turn 2-Watt
http://www.vishay.com/docs/57065/533534.pdf
Which I would highly recommend, the screw driver adjustments type will be at times really hard to deal with for fine combination pot adjustments there are several different frequency bandwidths groups that the circuits operate better on depending where all the pots are adjusted, it's just not adjust and your there, some stabilization is always happening ..... not like a sweep function generator with semi static "mean" numbers .....
Fuzzy  :)
Rosemary Ainslie
 ;D  Hi MileHigh.  You're definitely my favourite troll.  :-*
EDIT - I've now read on.  I really need to remember not to read you first thing in the morning.  You're definitely NOT my favourite troll.  I'm going to have to answer you at length because I just won't let you get away with all those generalisations.  You have no idea what you do to my peace of mind MH.  'blue' doesn't cut it.  If you ever get into preach mode give some light relief in MUSIC!!!!  There you know everything.
Frankly I prefer your x rated technobabble.
2ND EDIT.  censored.
Rosemary Ainslie
Poynt.  You're amazing.  I need to know how Spice managed that initial reversal?  Is it graduated during oscillation?  Or does it just do what you tell it?
Please post on Energetic forum.  I want Harvey to see it and he never takes his excursions here.  If I can swallow my pride surely you can???
EDIT Here's a post preface.  "On urgent application - I'm showing Fuzzy's waveforms."
poynt99
Quote from: fuzzytomcat on September 25, 2009, 10:53:00 PM
Hi .99
Fuzzy  :)
Glen,
I'm most likely going to start with the vanilla Ainslie circuit, i.e. 2.4kHz, 3.7% duty cycle, "standard" oscillation mode, and will be looking for anything COP>1. Rose would like me to pay particular attention to any negatives going back into the battery, and with the MEAN meter measurement, this will be a snap (of course once validated with the scope).
Then I may see about achieving the wild 555 oscillation, and if I succeed, I'll try to emulate it with a pulse generator. If I can do that, I will have proven my theory that the wild oscillation is indeed periodic. This will likely segue into a closer analysis of all the "net negative" stuff that's the buzz at the moment.
.99
Rosemary:
I'll take technobabble over psychobabble any day.
I am just going to keep my hands in my pockets, sit back, and watch the blinking lights.
Some music:
http://www.youtube.com/watch?v=p_euKhE7rw0
