0 Members and 188 Guests are viewing this topic.
fuzzytomcat
Hi everyone,
Here is a PDF published since 2002 by "Tektronix" called .... ABC's of Probes primer
http://www.afc-ingenieros.com/NotasTecn/Sondas/abc_sondas.pdf
also the "Tektronix" TDS 3000C series Digital Phosphor Oscilloscope User Manual .....
http://www.pewa.de/DATENBLATT/DBL_TEK_TDS3000C_MANUAL_ENGLISCH.pdf
Fuzzy
poynt99
Quote from: fuzzytomcat on November 10, 2009, 02:40:01 PM
Hi everyone,
Fuzzy
Good stuff Fuzzy.
I fully expected someone to find the ABC's one, it's very good. ;)
Check out Lecroy and Agilent as well.
.99
fuzzytomcat
Quote from: poynt99 on November 10, 2009, 02:46:22 PM
Good stuff Fuzzy.
.99
Hi .99
Your right about the Tektronix ABC's of Probes primer "PDF" .... I try to reference it as much as possible for those that are just learning about or getting ready to purchase an oscilloscope for the first time ....
http://www.energeticforum.com/62699-post12.html
I'll have to check out the Lecroy and Agilent as you suggested for any additional information ....
Fuzzy
poynt99
Fuzzy,
One more from Tektronix that is quite good:
Making Single-ended Measurements with a Differential Probe
http://www2.tek.com/cmswpt/tidetails.lotr?ct=TI&cs=apn&ci=3033&lc=EN
.99
poynt99
A rather good passage from the Agilent document here:
Oscilloscope probing for high-speed signals
http://cp.literature.agilent.com/litweb/pdf/5989-9177EN.pdf
QuoteEven if you’re measuring a single-ended signal, a differential probe always provides superior results, especially as the bandwidth of the signal increases. Remember, all signals are differential; “ground” is a convenient fantasy. A differential probe will have lower loading (higher impedance) for high-frequency signals in addition to higher common mode rejection ratio (CMRR).
.99
