how to make (and harvest), a miniature lightning bolt.
Started by nitinnun, June 20, 2009, 01:03:27 AM
nitinnun
Mk1.
my new research does not look like that, so far.
my basic theory is that electrons want to move from the negative pyramid frame,
towards the positive middle.
the electrons will polarize water/battery-acid, while they move away from the steel frame, and towards the positive middle.
if you allow the electrons to move from the negative half facing the positive middle,
and into the positive half facing the steel pyramid,
you will get electricity.
and since the electrons are still moving away from the steel pyramid frame,
towards the positive middle,
the water will instantly repolarize !
resulting in constant electricity !
electrons have LITTLE TROUBLE moving through air.
which is why peoples 12 volt batteries have been slowly recharged, just from sitting inside a metal pyramid.
because the electrons move through the air, into the battery. recharging the batteries electrons/electricity.
but it works better if you give the electrons a physical path to move from the negative frame, towards the positive middle.
and if you place more electrons inside the pyramid, in the form of water/battery-acid.
the more free electrons inside the pyramid, the more electrons moving away from the pyramid and towards the center, the more electricity available !
ResinRat2
Thunder Machine Motto:
"A generator on every downspout."
innovation_station
WITH TA IN LIGNTNING ...  COMES THE TUNDER!!   ;D ;D ;D ;D
IST
Mk1
@nitinnum
my drawing is a triple kelvin generator , with 2 microwave oven transformer connected in parallel between the spark gap on each side , creating a bemf and secondary coil induction for load.
Mark
http://www.youtube.com/watch?v=oY1eyLEo8_A
