Thanks to ALL for your help!!
Modernized Ark of the Covenant with 2 Tesla coils!
Started by gravityblock, June 20, 2009, 05:32:42 PM
onthecuttingedge2005
Quote from: gravityblock on June 21, 2009, 12:48:20 AM
Lambda (Λ) baryons containing 3 quarks.
(the Right Answer that leads to the right answer for the Pillars but not the total sum)
A Wimshurst machine?
you are grasping at straws here
You're talking about a UFO.
it's not a UFO, it is understood.
and yes, it is an interstellar vehicle of a different sort and not a UFO. think Time Travel and Space Manipulation using Archimedes inverse principle at C.
Jerry
gravityblock
Jerry,
Only thing I can think of at this time, is a Time Machine, which has already been mentioned here.
It is apparent that within the context of the surrounding verses you mentioned, if the cloud did not lift up, then they did not set out in their travels.  It also said, the Lord will meet you there.
I assume this allows one to time travel in the physical sense, instead of time traveling with your mind or thoughts, such as the Merkaba, which I did not look into in depth.
I am still studying this.
Peace,
GB
the symbolism of being stored in a Quantified State, see, not just one religion was effected but all religions under slightly different or stated interpretations.
