Mass can not slow time.
Started by brian334, June 25, 2009, 04:35:23 PM
gravityblock
The standard model has been good at predicting the elementary particles thus far.  All of the elementary particles discovered were predicted to have 0 mass.  The truth is, all of the discovered particles of the standard model has mass and this includes the photon.
This left the physicists trying to figure out where the elementary particles were obtaining their mass from.  So, they came up with the theory of the Higgs Boson particle.  The Higgs boson is the only Standard Model particle that has not yet been observed.
The Higgs boson particle (the God particle) is one quantum component of the theoretical Higgs field.  In empty space, the Higgs field has an amplitude of a non-zero vacuum expectation value. The existence of this non-zero vacuum expectation plays a fundamental role: it gives mass to every elementary particle, including the Higgs boson itself. This field is analogous to a pool of molasses that "sticks" to the otherwise massless fundamental particles which travel through the field (space), converting them into particles with mass which form, for example, the components of atoms.
As the elementary particles increase their speed through this field which has mass, the elementary particles obtain more relativistic mass due to the resistance of moving through this field.
Now, take an elementary particle that is massless where there is no higgs bosons sticking to it and no higgs field in space.  Let's say it can move from point A to point B instantaneously because it has no mass.
Now, we'll say some mass from the Higgs field has stuck to the elementary particle giving it mass.  It can no longer move from point A to point B instantaneously because of the mass it is carrying.  It will take Time to move from point A to point B now.
Now, we'll say as it moves from A to B it will be moving through the higgs field.  As it moves through this field, the elementary particle's relative mass increases due to the resistance of the field, and this causes it to take even more time to move from A to B.
If it wasn't for the Higgs Field, then the elementary particles would be massless and have an instantaneous speed, and Time would not be a factor (It would be outside of Time).
If the theory of the Higgs Field is correct, then the elementary particles that make up matter, now has mass due to the Higgs Field, which slows Time down.  The more mass it has, the slower it can move.  For the atom, this means it will tick or oscillate slower.  Since we are made up of atoms, then our brain waves will slow down, our heart rate will slow down, our thinking process will slow down, our clocks will tick slower, etc.
Space or the Higgs Field, which makes up space, gives matter or the elementary particles mass.  Mass gives the elementary particles or matter less Time.  Mass and matter are not the same thing!
0 mass = Infinite Time
Infinite mass = 0 Time
GB
brian334
gravityblock
Mass makes up the invisible world of space.  Matter makes up the visible world of space.
The invisible mass attaches itself to the visible matter, giving the visible matter mass.  The missing mass in a galaxy and the universe that physicists theorize about is the invisible mass that is not attached to any visible matter and they call this dark matter/energy.
The mass particle that attaches itself to the matter particle has a polarity and charge that is opposite to that of the matter particle.  This is the reason why mass attaches itself to matter, since they have opposite polarities.  Mass is a monopole and matter is a monopole.  When a particle of mass is attached to a particle of matter, then it creates a dipole.  Mass being the "N" and matter being "S", or vice versa.
Physicists have wondered why there is more matter than anti-matter in the universe.  This is because most of the anti-matter particles in the universe are making up the invisible particles of mass while the matter particles is making up the visible particles which has no mass.
I will continue this only if there is interest.............
GB
brian334
 I think atheists like Einstein can’t deal with the notion that the universe is infinitely big and the universe has existed forever. So daum people like Einstein make-up stuff.
nitinnun
"electrical resistance" can slow down time.
all mass has "electrical resistance".
though some atoms have more than other atoms.
time is slowed down, when it passes through mass.
but ONLY the time that passes through the mass, is slowed down.
the time that flowed AROUND the mass, is not slowed down.
i have noticed that electrical resistance GREATLY increases,
between 2 polarized/electrified objects.
if you placed a copper wire and a steel wire into a cup of water,
then connected a positive multimeter lead to the copper, and the negative lead to the steel,
then set the multimeter to measure the electrical resistance,
than the electrical resistance will likely read in the mega ohms !
that is right.
the mega ohms.
from copper and steel, sitting in water......
does time also slow down, if time passes through the copper, steel, and water ?
does time slow down slightly, if it passes through a capacitor which is holding a strong charge ???
