0 Members and 168 Guests are viewing this topic.
Kator01
@wattsup,
thank you. You are expressing what I have been wondering and pondering about.
I do not know if my last post is of relevance but a hv-transformer with clear specifications is needed in the first place before we then can build and test properly.
I think wesly willl pickup most of the things described here and we have to give some time so he is able to catch up with this one.
However I know from past developments it can be of fatal consequence if you rely on a specific electronic part ( russian flyback in this case) which is not available any longer. It might cause a full-stop in further development aside from a lost possibility to be replicated by others.
Kator01
stivep
wattsup
read what I said above your comment again.
I have add into this comment a lot.
My normal response is  write post and than hours for editing it when is already published
In most of situation I post note at the end of comment that I'm still working on it
Partial answer why we are changing schematic is there
some of new the schematics are just approaches
Some of them are  theoretically thought and did not tried as of yet.
The goal is to  encourage  others to give us helping hand
Antanas is a guy  who does excellent job in documenting everything but he is so fast that it is not always good  for  the interest of all of us.
There is a lot of misinformation going on here by that speed up.
But from the other  hand Without Antannas part of us  especially Russian speaking would need have chance to participate in progress
Please understand that
1.IT IS NOT US AND IT IS NOT WNY GROUP THAT IS LEADING
2. WE DO NOT CARE FOR AUDIENCE  RECOGNITION BUT FOR AUDIENCE BEING INFORMED.
3.THERE IS NO PERSONAL GAIN  FORESEEN AS MAJOR GOAL.
4.WE ARE NOT FREE OF ERRORS AND COMMUNICATION PROBLEMS.
5.Roles of each  of us.
- Aidas the most technically in speed
- Arunas schematics and concepts drawing to present it to group
- Wesley.. nobody special.. :) :) some of testing , verifying, replicating
-all of us ... yesterday 8 hours of talk
occasionally Aidas publishes his own  vision of our discussion
Wesley
PS: there is no easy way for me to respond to  forum
I'm getting enough of questions from around the world that could keep me busy for 24/365
Can not do it...
whatsup thank you my friend.. Maybe you will be able to get what we all want to get
Device  with self looping and no external power supply such as TK
forest
Quote from: ronotte on January 29, 2012, 04:25:44 AM
@kator01,
- Cu slotted tube: lenght= 10cm, diam=10mm, wall thickness=0.6mm
- Ferrite rod diam= 9mm, lenght=10cm
- Cap on AV plug may be any value between 1n and 10n: it set the spark repetition time, the lower value the faster timing
- Cap on output diode. I used 1n in order to see well the staircase waveform.
have fun
@itsu,
it seems to me that you are using an enormous kacher (450t on sec) It may be good as it could deliver probably 3-5KV @ a lower frequency but then the 1n4007 rated only lKV are dangerous ???  I warmly suggest you to use standard HV diode rated at least 15-30KV @100-200mA. I've seen also that you used the standard bridged output to rectify/drive the load: that's not what intended by the STAAAR team as it does not provide for blinding the lamp load presence.
Roberto
slot size ?
ronotte
@wattsup,
thank you very much for the lucid exposition on actual understanding about Pickup coil device: WELL DONE.
Yes, I thought also many times about the additional coil (you called it SFC) on TBC but all stopped when I saw the schematic version#2 cited several times by Wesley where the TBC's main coil (low side) connected directly to system GND (no more SFC). So, what we are supposed to think? No words about that from Wesley.
Of course in such a situation is very difficult to give a proper weight to your rumblings on the SFC presence: may be that's the key or may be not. I think that for us is almost impossible to replicate it as we do not have the same Russian TBC.
As I said many times the device works by charging the interwinding capacitance between the CC and the Pickup coil. In order to operate properly this stray cap must be at list 140-170pf as Wesley reported several times.
Up to now I confirm that I still do not see any OU even if operating at 6KV...only a little light from lamp while dissipating at least 30W from DC power supply. That is my situation, of course the WNYg group is on something that they do want to understand before releasing.
For the up mentioned reasons I chose to follow an alternate route using the kacher in order to build my own base of knowledge on the matter.
A last consideration: watching the Wesley's video clip ("The smart scarecrow show" -20120126 - Wesley from New York project update) is really not clear what Wesley moves in order to tune for max light. My impression is that he is changing the frequency of the oscillator that is driving his TBC but it could be only the TBC power supply: in this last case he changes mainly the SG repetition rate.
@Khwartz,
I apologize not responding to your question. My opinion is that for the time being as I am not searching for power but rather trying to improve my knowledge, I think that the quadratic behaviour of the right trumpet's pic bears much more importance than the associated integral power. It signal to us a possible diverging operation that could lead us to OU. What happens is that something is limiting said exponential rise...IT IS THE FIRST TIME THAT I SEE SUCH KIND OF WAVEFORM ;D
Roberto
