0 Members and 78 Guests are viewing this topic.
T-1000
Quote from: jbignes5 on May 20, 2012, 03:07:52 PM
But as Tesla said this is not static it is static like. The problem with static is that it is not polarized. Maybe thats where the Testatika machine had polarizing magnets that the wires ran around changing the static to electric energy I bet. The pictures show magnets like alinico with each polarity N and S having wires coiled around the magnet legs. Could this be a way to convert static to electric phenomena?
In case of magnets with coils - it is the answer to question how to modulate static magnetic field what needs to make AC electric field. Hit the resonance and here you have magnet as energy source...
forest
wattsup
How old was Hubbard when he built his 40kW generator ?
T-100
how to modulate magnetic field of coil completly...  on/off  ;)
T-1000
Quote from: forest on May 20, 2012, 03:29:44 PM
Due coil inductance and capacitance there is always LAG time.
And you need to match magnetic field strength of permanent magnet when switching coil ON.
Also when you switch coil OFF it produces BEMF and Lenz law is there.
So there is optimal resonant frequency... :)
stivep
Quote from: jbignes5 on May 19, 2012, 09:28:01 PM
Answer to first question is actually another question. What do you think is under the silver metal boxes? There are wires coming from them.
Definitely not  bank of capacitors as there  is no need to cover it and no room to store it. compering to show to me  by TK there was no spark gap there as well.
So where you will put interrupters? And How will they look like ?
Next question will be any presence of high power generator? The heat sinks for transistor must of be humanness and fan must be present. I did not see any opening for air ventilation in silver box. for proper circulation  you need two slots.
QuoteAnswer to second question. First a little statement. The guys that are there are the ones who afforded the whole setup. You know this. Now for the answer.
No, they did not need to be worry  about it. "Plenty of food was there for the birds about 2.5 m.....n of seeds but in small frequent containers. "
QuoteNope the motor was just an Inductive load, with the lights being a Resistance load. They were showing the load capability of the unit especially with different kinds of loads. I would hope you do the same right? Just testing with lights would be nothing really.
They did not test anything, everything was already tested.THAT WAS  THE SHOW. The show had one goal to attract buyers.
But current under load for motor is  significantly big comparing to current with shaft in free turn.
The only moment  when you need current is when you start it.
At that point  motor was the only load  present. The power to start motor comes from grid.
When  three switches are  flipped down than is when  motor  in motion by inertia switches to  generating mode.
BEMF is sustaining factor at that very second.the impulse forming  ignitors get their charge.
There are 4x3 of ignitors .= 12
Each phase  got 4
what is  under metal box?
I do not know ( plasma bulbs)? 3 legs plasma vacuum  in glass envelope?
Something that must be essential , significantly = the secret of  TK.
Put the connection on the paper if you feel  it is different.
I can not do it I'm mostly theoretical beast.
My time is reserved to GTBTB as soon as possible.
Even tomorrow  for that I need to finish what I'm working on.
QuoteAnswer to third question. Yet another question. What exactly is an igniter? Is that a spark gap? Again please refer to the metal boxes. Metal boxes=shielding
As metal boxes concern ( Square one enclosure) I explained  above.
http://www.advance.philips.com/documents/uploads/literature/RT-8100-R02_1209_HIDPcktGde.pdf
page 14
page 24
page 31
page 37
page 38  schematic
When the lighting
system is energized, the
ignitor provides the
required high voltage
pulse until the lamp arc
is established and automatically stops pulsing
once the lamp has started. It also furnishes the pulse continuously when the lamp has failed or the socket is empty
Some ballasts have an
integral or built in ignitor. If you are not sure if an
ignitor is used put a capacitor across the meter for
all open circuit voltage measurements.
When the power is cycled off and back on via a
circuit breaker or switch, other fixtures on the same
circuit will extinguish and not come back on until the
lamps cool. The energized ballast will continue to
produce high voltage starting pulses for a specified
period, usually between 10 and 30 minutes depending
on the ballast model, allowing enough time for the hot
lamp to cool.
Electronic Ignitor CD-7 for sodium lamps and metal halide lamps
http://www.alibaba.com/product-gs/347527628/Electronic_Ignitor_CD_7_for_sodium.html
QuoteDid you look at the 3 coil towers in the back. They have the same flat wound(bifilar?) coils under the stacks. Also the 3 coils in front have no stands or flat wound coils.
And what is that you try to  point here
draw schematic please
Balast are not capacitors
Igniters are not capacitors
capacitors and ignitors are  elements of balast
It is
important to note that ignitors are specifically designed
to operate properly with specific ballasts and cannot
be interchanged with other ignitors or different brands
of ignitors and ballasts. The ignitor should always be
mounted near the ballast but not on the ballast.
Just for you my friend: picture grid as motor and motor in tent presentation like motor to.
move the shaft of first one  and second one will get the charge.
"Disconnect" than one from the second one and use free motion of the second one to power ignitors( impulse  forming device)
The energy  from second motor will be the energy from motor acting as generator.
Than you need rest of what we know  and  we do not know.
That motor will be used than as PUSH PULL GENERATOR my friend !!
There  at this point is no room for any other thinking.
Unless you are genius
Wesley
PS: Good question is what are the stands beneath- at the bottom of the main coils.
Are the posts represents primary of Tesla coil?
Or/and containers  for something  we do not know.
did you notice any wires coming out from it?
Definitely there is relation between bank of ignitors and coils without base.
It looks like only this set of coils is commented to them.
