0 Members and 352 Guests are viewing this topic.
anandml
 :(  In 2004 video TK replication is very simple while we compared to other videos so first we should find the secret of tin can video that means what is placed inside the tin can (motor or transformer or ignition coil) after finding secret of tin can video only we can able to find the secret of other replications (aquarium box , plastic box) In aquarium box circuit is very much complicated actually it may be easy if we know the working principle of TKs replication. One thing confirm theoretical ideas not enough for making TK device, we should do more practically. The real secret is he was using inverter for constant 220v ac power supply with less ampere . More ampere will be generated by circuit placed inside tincan So he is tried to hide that one..low voltage 20-30v & high ampere 20 -25amps from tin can  is mixed with 220v less ampere 2 amps  from inverter will help to give 5Kw output.
        @stivep he shows the circuit diagram of tin can video I cant able to tell it will work or not  without practical making of circuit, but sure some parts of circuit will be correct. Next side the stivep circuit not matching with TKs patent. In that circuit there is no transistors, while we  compared to 2004 video TK using two transistors . Any way next week onwards I will start continue my work with Tk tincan video based project. I need ur help for that one. I think this is my lengthy post..
ANAND.M.L
jbignes5
Interesting idea.
More on the tubes idea.
"Replacement of pulse generator 7 by a suitable vacuum device, as diverse as a fluorescent light bulb (as a diode) or a deuterium triode indicates that, despite the absence of desirable physical parameters identified in the parent application, any cold cathode operated vacuum tube device capable of endogenous pulsed abnormal glow discharges through spontaneous autoelectronic cathode emissions when operated in the abnormal glow discharge region, is capable of serving as the pulse-forming discharge tube in the circuit. By contrast, whilst discharge tubes operating in the normal glow discharge region can be used to form pulse generators, the mechanism is different and the power output would generally be too low to be useful in an electromechanical application."
This is from http://www.rexresearch.com/correa/correa.htm#5449989 About 1/3 the way down.
So maybe he wasn't using the tubes in a normal manner. And maybe he was shielding the tubes in the tin can. There is a great many wires going into the can if you watch the video. Just under the metal tab welded to the top.
There is also some news I need to report. Listen very carefully to this report. They are now adopting my theory of the smallest particles. They have been forced to see the light finally.
http://www.rr.com/video/2253381377
This reference to the Higgs particle and field is what I have been trying to say in my theory, which was formed by the writings of Tesla and many other great scientists of old. Here is a good read about it.
http://www.msnbc.msn.com/id/48062124/ns/technology_and_science-science/
Pay attention to words like em field and potentials. Fluid like responses as well like sloshing.
Zeitmaschine
Yes! Kapanadze has discovered the Higgs particles already back in 2004 and converted them to free energy straightaway. 8)
forest
Quote from: Zeitmaschine on July 05, 2012, 01:35:16 PM
He send one to CERN lastly concerned of repeated failures and costs of keeping running it and fixing againg and again. They checked mail and voilla ! they reposted success. Indeed in mail was Higgs particle.  ;D
gints
Unity Does Not Always Equal One
It begins with an understanding of unity gain. Simple enough. Ask anyone and they will tell you unity gain means that if I put, say, 1 volt in, I get 1 volt out, i.e., a gain of one, or unity. Nothing could be easier. That is until that same someone asks the question,
"Is that unity gain balanced, or unbalanced?"
Herein lies the problem. Today we find that many (most?) pro audio signal processors have a gain difference of 6 dB between unbalanced and balanced out (exceptions to this are units with output transformers, or cross-coupled output stages -- see Appendix). This x2 difference results from differentially driving the line. Figure 1 shows how an input signal drives one side of the line positively and the other side negatively (each line driving amplifier has a gain of one, but together they yield a gain a two). For example, a +1 volt peak AC input signal drives one side to +1 volt while simultaneously driving the other side to -1 volt. This gives a balanced output level of +2 volts peak (the difference between +1 volt and -1 volt). Alternatively, that same input signal drives an unbalanced line to +1 volt peak. Thus, there is a 6 dB disparity between an unbalanced and a balanced output -- a gain difference factor of two.
Here, unity equals two.
http://www.rane.com/note124.html
