0 Members and 347 Guests are viewing this topic.
frankidel
Hi, just a thought, why TK is using copper tubing, could it be vaccumed or filled with a gas, it is soldered on both ends, maybe filled with inert gas.
forest
cheappower2012
Very nice analysis. However the most important is how thick coil is connected and all those connections near roundbox. I believe that round box is glued to the table, contains inside a motor and maybe a flyback with small circuit. If you could trace copper strip I think it would help ;-)
Something interesting in picture.... seems that table was extended with a piece of wood and additional legs, but there is something here, maybe a metal cover on tabletop ??? If so then I would put radiators on this metal and connect via copepr strip. If there are mosfets/high power transistors attached to radiators. Not sure about that, maybe they are just diodes.
Frederic2k1
Quote from: Zeitmaschine on July 23, 2012, 02:25:47 PM
Then I have next idea #1: The spark goes on automatically when the lamps are switched on (in bright light the spark is not visible.) Hence a spark in advance is just a showcase, but not necessary for functionality.
Then I have next idea #2: What if there is no separate high voltage generator (like a flyback) in TK device, but the coil produces the high voltage by itself (in resonance)? Primary coil with 5 windings, secondary coil with 50 windings, that is a ratio of one to ten. Unload a capacitor with 300V into the primary (loaded from 220V supply × square root of 2) then theoretically the secondary should produce 3000V. Then loop it back.
Maybe something like this: Installing Tariel Kapanadze
If one gets this to work let me know. In the meantime I will try to catch the sense of these lines. :P
VERY Interesting... It all boils down to making decreased ground levels or what tesla called "virtual grounds" in his oscillator-shuttle-circuit. Do you have more of this stuff or is there anywhere a correct translation. Sadly the common browser-translator are not the best to do it.
And thank you also for the link of the plasmaversum. I watched the 3 hour movie and it was pretty amazing. It radically changed my view of this world. Is this an act of suppresion to not let the publicity know that the stars and everything else are only electrical phenomenons ?
Again thank you.
regards
cheappower2012
@forest,as whats in the box,the connections,I'm working on that and plan to build a prototype
soon.Most important thing is to keep it simple,TK is not an electric engineer,hes a tinkerer,my opinion is the TK device
is simple but very strange,its an accidental discovery by TK.You have to remember bigger spark
means nothing,the flyback circuit does not have to consume a lot of power to work
in the TK device,that's why its not a Tesla device,the field produced by the spark,performs a special function,
its not to produce induction as in a Tesla coil.As to all the other connections and parts external to the can, they do nothing
its a trick to fake you out,remember in the video the fat guy in the suit was watching the
demonstrations,the other connections and parts are to fake him out.Transistors with only two wires can not work,the transformer and diodes are wired very strangely and the wires connecting the rectifiers to the can are really small makes no sense,only if they do nothing does it make sense.The fat guy in a suit came most likely from the turkey company,hes in the turkey video.
Only  the main connections are functional,the rest is to fake you out,this device is real simple
but strange this is the reason why its so hard to figure out.Adding to the complications is that the inventor adds fake parts and lies.
This tactic was used by SM inventor of the tpu.My opinion is if you looked inside the can you would not see very many parts.Here's a story related to the tpu
SM made two big tpu's,people that knew about the tpu broke into hes house and stole one
they still did not figure out how to replicate it even with a unit.
energia9
Quote from: cheappower2012 on July 25, 2012, 04:30:43 AM
YES YES YES!!!!
