0 Members and 71 Guests are viewing this topic.
Zeitmaschine
Quote from: Free.Energy on August 12, 2012, 07:58:47 PM
Transformer theory is well explored well understood.  There is not magic in a transformer because there is no magic in an electromagnetic field.
Except no one can say for sure what an (electro)magnetic field actually is. A property of the ether itself is the latest theory, I think.
It is not the frequency that changes the ether it is the sudden change in voltage and high voltage is required.
And this is exactly the problem with the TK device. As can be seen in the 2004 video (as mentioned before) the lamps are switched on at 20.48 but there is clearly no spark visible prior to this action. No spark means no high voltage and no high voltage means the spark gap and the helical coil are useless and not needed to get over unity.
Koen van Vlaenderen has a theory.  This is not complete but looks good and explains many things I have seen or read about and not understood.  I understand much better now.
The page about hoaxes is very good and exposes Bearden, Bedini, Tewari, and others as the frauds they are.
Let me guess: Van Vlaenderen has not a single working OU device in his hands but he can tell quite certain which device is real and which device is hoax. :(
Free.Energy
Quote from: Zeitmaschine on August 12, 2012, 10:46:25 PM
There is no spark because the energy is not built up high enough at this point in time.  The spark increases when the load is turned off in the 2012 video as the energy is building up faster since there is not load.  The spark is dissipating the excess charge.
I have seen these things in pulse experiments and the energy will dissipate one way or another.  I had very loud expolsion sounds with no flash. Another time I accidentally grounded the energy across my body when touching a power supply and it shorted the main transistor in the supply.  This shorting happened twice and the third supply was a tiny flyback and it caught fire when the transistor shorted.  These problems were when using a dual spark gap and the energy was built up at the power supply which was not grounded.
It's not overunity, it's longitudinal induction (longitudinal waves are scalar waves).
Has anyone visiting Kapanadze ever just gone outside and pulled the house main breaker during a demonstration?
I know it would cause chaos... but imagine if his device kept running. You could just patch it back in to the house circuit and continue on with the party.
wattsup
@all
I'm afraid the 2012 video was taken by SM's camerman. I thought I promised myself not to get into such video anymore. Major waste of time especially when the video quality stinks.
lol
I'm laughing but it's not really funny.
@forest
I need to know something. The picture you posted here.....
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg331743/#msg331743
from the 2012 video was grabbed when. I did not see anywhere in the video an angle shot like you grabbed, or do you have another copy? The one I have is this..
https://www.youtube.com/watch?v=-4L0w56pa60&list
@cheappower2012
How the hell did you get such clear images? And, again when did you grab those because again they are not possible with my copy.
@all again
Question or Observation..........
If the ground cable and nut was a real ground that has no real potential, then why go to the trouble of covering it with a wooden plank plus a mason's brick as well. Seems not every insider thinks that ground is just a ground.
Then, why should a simple bolt in a cement block constitute a real ground?
Something seems not right in Georgiaville.
Could this be so simple as transmission of power via one wire.
Hmmmmmmmmm.
Naaaaaaaaaaaaaaahhhhhhhhhh.
Can't be.
wattsup
frantz
Quote from: wattsup on August 13, 2012, 12:34:45 AM@allI'm afraid the 2012 video was taken by SM's camerman. I thought I promised myself not to get into such video anymore. Major waste of time especially when the video quality stinks. lolI'm laughing but it's not really funny.@forestI need to know something. The picture you posted here.....http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg331743/#msg331743from the 2012 video was grabbed when. I did not see anywhere in the video an angle shot like you grabbed, or do you have another copy? The one I have is this..https://www.youtube.com/watch?v=-4L0w56pa60&list@cheappower2012How the hell did you get such clear images? And, again when did you grab those because again they are not possible with my copy.@all againQuestion or Observation..........If the ground cable and nut was a real ground that has no real potential, then why go to the trouble of covering it with a wooden plank plus a mason's brick as well. Seems not every insider thinks that ground is just a ground. Then, why should a simple bolt in a cement block constitute a real ground? Something seems not right in Georgiaville.Could this be so simple as transmission of power via one wire.Hmmmmmmmmm. Naaaaaaaaaaaaaaahhhhhhhhhh.Can't be. wattsup
Dear wattsup,
If you ask about pictures in HQ,
You should read whole posts of a.king who's published this photos previously before video.
And everybody starts to using to analysing those pictures. This is the secret of hq photos.
