0 Members and 224 Guests are viewing this topic.
v8karlo
Caduceus coil is pure capacitive coil.
I played with it for a long time.
If you wind it with wire of different color, you can clearly
see plates of cap. Windings must be tight, closest the plates,
stronger the capacity. Connect it as scheme shows, just like bifilar
one and it will yield great results.
There is one other thing about it. On the up and down overlaps
it emits strong pulses.
It gives me something to think for a while and whats happens is that
electrons travel through windings in different directions, and when they
hit overlap points, under their strong repulsion they have been ejected
from coil.
Caduceus coil, when operating with heavy load emits strong pulses which
lit diodes on my Pc keyboard meter away.
After I understood whats happening I came up with HV experiment and it
succeeded.
HV Schematic is attached below.
This is very strong force and my intentions were to instead of small cap put
capacitor coil  as an driving coil. It would be far stronger then classic induction.
That was my first thought that TK is doing just that with his big Capacitor coil,
but never tried.
Now you know everything I know.
Bernhard
EN: I while reeled up the small coil model and experiment with connections, and giving of different signals, when I will gain any effect that I will report ...
RU: Я пока намоÑ,ал маленькую модель каÑ,ушки, и эксперименÑ,ирую с подключениями и подачей разныÑ... сигналов, когда получу какой нибудь эÑ,,Ñ,,екÑ, Ñ,о сообщу ...
Alexol
v8karlo
In the diagram, indicate the point at which the spark gap is installed.   Please.
Hoppy
It is easy enough to transform low voltage levels to very high voltage levels using coils, spark gaps and caps in various configurations. However, TK appears to be producing at least 200V at 20A continuous current with his device. That's a whole different ball game which requires more explanation than has so far been put forward in this thread.
Hoppy
starcruiser
The spark gap in this setup is for demo purposes only as this is on the output of his trafo setup. In all cases I am thinking the SG is for over voltage protection and not part of the power generation, at least in this situation.
I am getting ready to try a few experiements myself, just finishing up my secondarys for my Tesla coils then I can focus on the cap coil idea, going to try air core first then try with a ferritte core. Now what would happen if one would cascade 2 such units? what would the output be?
This setup reminds me of the SM TPU large center core torrids, I wonder if this was the secret, input caps (yellow), 555 timer circuits for driver and a second air core coil for amplification, just thoughts... something to try I suppose.
Regards,
Carl
