0 Members and 346 Guests are viewing this topic.
v8karlo
Quote from: Jack Noskills on August 18, 2012, 03:02:12 AM
v8karlo, could you test drive my version of your circuit ? Your circuit gives volts, my circuit divides volts but increases amps. What if combination of those two circuits would give the power ?
First you would need to play with my circuit alone, I have tested it only at 50 Hz sinewave. No idea how it works with higher frequency or with square input. If results are good, then you could add this at your output/input to get the missing amps. You should try this using toroid shape as toroid is much more powerfull than rod shape.
Yes , I would be glad to assist you.
My mail is
v8karlo@gmail.com
Can you send me your latest scheme and your opinion what you
think is going on in your circuit.
Maybe some unusual behaviour of your coils you observed.
(I have many for my coils, thats why I am asking this)
Jack Noskills
Quote from: v8karlo on August 18, 2012, 05:42:54 AM
My mail is
v8karlo@gmail.com
There are pictures on page 3 at http://www.overunity.com/12487/simple-to-build-isolation-transformer-that-consumes-less-power-than-it-gives-out
If this is not clear then just PM me for questions and lets get any details sorted out of this thread, there are too many pages already lol. Basic difference is that you are taking power from the ends, I take it from the middle. I will now go and try your setup so I can compare it to mine, I got some diodes.
v8karlo
Few more things I just remebered.
If you use trafo with more coil turns, voltages will go sky high.
If you use trafo with less coil turns, amperage will increase.
(Ohm law, resistance of coils)
Best coils are with fat wire, zero ohms. (20-30 turns)
If you do this on rod type core, polarities of second coil will be inversely,
so you cannot use this scheme for rods.
v8karlo
That is why on rods you wind coils in opposite direction,
to maintain polarities in correct order.
verpies
Quote from: v8karlo on August 17, 2012, 08:22:21 AM
Wire is 0,75mm litz wire from ordinary house cable
Ordinary "house cable" does not use Litz wire !!!
In Litz wire all of the individual strands of the wire are insulated from each other by enamel.
In ordinary "house cable" all of the wire strands are touching each other are not insulated from each other by enamel.
