0 Members and 65 Guests are viewing this topic.
Hoppy
Quote from: wattsup on August 19, 2012, 09:56:07 AM
So this TK coil is not wound with 14 awg mutil-strand copper wire.
See image below shows a close-up of that connection to the transformer and compare it too an image I took of my 14 awg. I would say the blue wire is a HV type wire of 18 awg at best but able to handle high voltage at a good amperage.
wattsup
Agreed. So, what does this tell us about the load?
anandml
IMPORTANT NOTE
After watching TK 2004 video again and again i can able to understand only one thing he used spark gap for decoration purpose only. TKs spark gap is 100% fake. With out spark gap the device will run continuously. If there is no need of  spark gap what is the use of transformer , rectifier, transistor etc. Inside tin can he placed fly back transformer ok.. remaining place he utilized for hiding capacitor or any other items. IF anybody have idea about that? ???
In patent he didn't mentioned high voltage because there is no need of  spark gap.... Why he use diode???
Due to wire stretching fly back transformer ground connection is disconnected So no spark present after connecting the battery charger. pls watch video again and again
27Bubba
by:wattsup
"So this TK coil is not wound with 14 awg mutil-strand copper wire."
Is it possible that TK used a coax type wire. I know of couple with thick center conductor and thick center insulation as well.
@Hoopy
"There are clearly some people posting in this thread that do not have even a basic grasp of electrical principles and yet are trying to unravel the mystery of the TK device by experimenting using circuitry and test equipment that work on these very same principles! :("
Easy now Einstein!
Not everybody can be as sharp as you when it comes to electrical principles.. TK stumbled on something that you and anybody else yet replicate, and he done with very little of basic grasp of electrical principles... >:(
forest
Anybody trying to understand should look for principle in mechanical effects. I'm quite sure this is the same gravitational/mechanical  energy consumed. If I would be in TK place during those 16 years (!) from 1996 I would first like to know everything about the power source and eventual radiation or EM radiation from device.
Just placing device in mineral oil will answer some questions and TK did that. Radiation can be measured by poor method running device for 24 hours with a photographic paper in black envelope placed everywhere around, the only problem is neutron radiation measurements. The last one would be Faraday cage and I would make 3 stages Faraday cage and give it a try. The last check would be difficult - require a underground lab and a lead wall room for testing if the energy is not taken from EM radiowaves (checked with wideband radio receiver first - it shouldn't note any radio station or signal).
Consider that as preliminary tests. As you see TK is not just a crazyman doing the show. He fulfilled the basic requirements (add to it also testing on island) - whatever he could do.
If I'm right that kind of devices cannot be scaled up without dangers.Or you have to have  knowledge better then Tesla had.
a.king21
Quote from: Hoppy on August 19, 2012, 08:30:36 AM
Could the original 350 meg vid be made available to us for study?
Hoppy
I'm working on getting an original copy. Could take a few days.
The English team met Kapanadze for the first time during the making of the aquarium 2 vid.
They are not mugs either. Mike has 2 patents out for a HHO product already.
(Mike's the guy providing the commentary and taking the video.)
