0 Members and 36 Guests are viewing this topic.
frantz
Quote from: Zeitmaschine on August 31, 2012, 05:00:37 PM
They are all waiting for the new laws of physics to be officially established. :)
I still don't see how a coil with 78 ohms resistance can provide 9 amps of current at 220V. Hence
a) either new laws of physics are in place or
b) this circuit is a piece of legerdemain.
Anyone tried to power a 2KW (25 ohms) heater with such a small transformer (78 ohms secondary) the standard way by connecting the primary to the grid?
A KD502 can do 20 amps but only at 60 volts. That means the voltage of 220V must originate in the transformer. So this transformer is a magic one after all.
And the blue coil still does nothing except to cancel out its own magnetic field because of the reversed windings.
Hi Zeitmaschine
we must start thinking self. Not still analysing TK pictures...
verpies
Quote from: Osiakosia on September 01, 2012, 01:52:44 AM
And how is about of influence of generator parameters ?
Grammar prevents me from understanding it unambigously.
Do you mean "And how about the influence of generator parameters on ...?"
If yes, then "...on what" ?
The best signal generator for eliciting NMR or ESR responses out of any material is a generator that allows the varying of the phase offset between 2 channels. For example this Signal Generator.
Zeitmaschine
Quote from: frantz on September 01, 2012, 03:21:48 AM
Hi Zeitmaschine
No problem. Since the TK transformer apparently violates Faraday's law of induction and/or Maxwell's equations these are good starting points for such adventures (like thinking self). ;D
Now, who finds the wrong formula in these equations? 8)
verpies
Quote from: T-1000 on August 31, 2012, 08:31:16 PM
For NMR - first of all you need to imagine entire picture in 3D how each little compass needle (atom spin) can be rotated when you introduce two magnetic signals on 90 degrees to each other. Then you need to keep one signal as current for driving transformer action and second on making core's atoms spin to dealign from main polarization on their natural resonant oscillating frequency.
That's sound advice.
I'd like to add that the statement "introduce two magnetic signals on 90 degrees to each other" can mean two things:
1) these 2 magnetic signals must be 90 degrees out-of-phase to each other.  This is a temporal relation.
2) these 2 magnetic fields must not be parallel to each other in the core (perpendicular is ideal).  This is a spatial relation.
P.S.
"Perpendicular" or "Parallel" refers to the spatial orientation relative to the shape of the core material.
