0 Members and 68 Guests are viewing this topic.
verpies
Quote from: calim on September 04, 2012, 08:42:35 AM
Thanks... And what does happen to the "used" copper ? I mean what does it looks like once used ?
Basically, a little of the copper changes into Zinc or Nickel, but the amount of transmuted copper is so small that the depleted Multiplication Disk/Ring appears the same to the naked eye, it just has a little bit less mass. ( apx.: Î"m=E/c2 )
verpies
What is supplying the power to light those light bulbs when the brass disks are not spinning in this Kapanadze video ?
Also, why a little bit later, the men move away appearing agitated?
yfree
Quote from: verpies on September 04, 2012, 01:47:16 PM
This, in my opinion, is very simple. This is actually the part that finally convinced me that the spool device is  the ultimate conversion device in all TK's demonstrations.
In this video, at first, TK is using the output of the generator/pulser part in that box to excite the internal device. Next, he disconnects the internal device and uses the generator/pulser to excite the electromechanical spool device. Then, he rewires the output of the generator/pulser again, to power the internal  device. This internal device is equipped with the pick-up coils and therefore can power the bank of bulbs. Both devices can be powered by the same generator/pulser. This, of course, implies that both, the external and the internal devices are very similar spool-type devices.
The running away can only be explained by TK mentioning the word "radiation" or similar...
Shokac
how Kapanadze make strong rotation field with this toroid?????????
yfree
Quote from: Shokac on September 04, 2012, 03:54:40 PM
how Kapanadze make strong rotation field with this toroid? ??? ??? ??
First of all, this is not a toroid. This is a regular coil disguised as a toroid. The coil forms a transformer with the other coil fitted in the axle.
The torque is not generated by this coil. Torque is generated in the disks. Read the second part of this article carefully.
