0 Members and 45 Guests are viewing this topic.
wattsup
@all
I forgot to mention something about the coax. You should be able to find good coax cables made  for microphones and electric guitars that have very generous top quality shielding with a nice stranded center line to augment skin effect.
If I remember correctly there is a brand name like Canare that you can find on ebay with original blue or orange colors.
wattsup
Zeitmaschine
Quote from: FreeEnergyInfo on September 15, 2012, 04:38:11 PM
IN 900 W OUT  2.3 KW FREE ENERGY !!!!!!!!!!!!!!
Interesting! Loop it back and make a self-runner! 8)
Let's hope for a moment the measurements are true then what could be the physical basis for this?
Take a look at the image below (courtesy wikipedia) showing the coil of an induction cooker and then take a look at this patent stating:
»5. A cooker heating system according to claim 1, wherein the bundled conductor is made of several of the single conductors twisted to form a litz.«
and
»6. A cooker heating system according to claim 5, the bundled conductor being a litz consisting of five to nine strands, each strand including five to nine single conductors insulated electrically against each other.«
Then take a look at the statement from my previous post and compare: »The inventive method for generating energy by means of ... two or more radiators of electromagnetic waves operating synchronously into one load.«
What does this imply? Are the »five to nine strands, each strand including five to nine single conductors« which the induction coil consists of the »two or more radiators of electromagnetic waves«? And if so, then the cooking vessel or the pick-up coil is the »one load«?
Now the question: What could this have to do with the Kapanadze 2004 setup?
T-1000
Itsu, watsup:
http://www.energeticforum.com/renewable-energy/4864-donald-smith-devices-too-good-true-244.html#post208715
http://www.liveinternet.ru/users/edward_lee/ - Dally blog web page for those who are interested.
"Ну и Ñ,еперь по Ñ,еме , Ñ,о есÑ,ÑŒ по усÑ,ановке:
Ð' усÑ,ановке два генераÑ,ора , один генераÑ,ор раскачиваеÑ, преобразоваÑ,ель на Ñ,,ерриÑ,овом Ñ,рансÑ,,ормаÑ,оре для пиÑ,ания генераÑ,ора наносекундныÑ... импульсов и сооÑ,веÑ,сÑ,венно для подачи напряжения на каÑ,ушку, далее каÑ,ушка: сосÑ,оиÑ, из класÑ,икового каркаса и содержиÑ, 3 обмоÑ,ки, одна обмоÑ,ка - провод приблизиÑ,ельно 0,25- 0,3мм (Ñ,очно скажу Ñ,олько когда разберу ее с Ñ,очными замерами, когда-Ñ,о моÑ,ал мини Теслу, поÑ,ом она обрасÑ,ала дополниÑ,ельными обмоÑ,ками в Ñ...оде эксперименÑ,ов ). Ð"алее поверÑ... нее обмоÑ,ка проводом 0,65мм (назовем ее резонансная , она подключена Ñ,олько на конденсаÑ,оры 1,5мкÑ,, Ñ... 400в). Ð"алее обмоÑ,ка коаксиалом 50ом( ранее применялся в компьюÑ,ерныÑ... сеÑ,яÑ...) получаеÑ,ся биÑ,,иляр - конец обмоÑ,ки закорочен - нагружен на генераÑ,ор наносекундныÑ... импульсов.
Ну и сверÑ...у намоÑ,ана обмоÑ,ка для съема.
ОбмоÑ,ка съема нагружена на диодный мосÑ,, после диодного мосÑ,а сÑ,ояÑ, конденсаÑ,оры (ОбязаÑ,ельно не полярные! Полярные не выдерживаюÑ, и прошиваюÑ, или за несколько секунд надуваюÑ,ся!)
После выпрямиÑ,еля я нагрузил лампой 20 Ð'Ñ, ну и сооÑ,веÑ,сÑ,венно блок пиÑ,ания для самозапиÑ,ки.
Но еще, у меня блок пиÑ,ания зарабоÑ,ал Ñ,олько из чеÑ,ыреÑ... один, причем сÑ,арый АТ. Один не зарабоÑ,ал вообще, два бысÑ,ро вышли из сÑ,роя.
Ð"иодный мосÑ, между конденсаÑ,орами и каÑ,ушкой обязаÑ,елен! Ð'ез него неÑ, сÑ,абильносÑ,и рабоÑ,Ñ‹! Если кÑ,о Ñ,о будеÑ, меня учиÑ,ÑŒ сÑ...емоÑ,еÑ...нике - я знаю, чÑ,о в блоке пиÑ,ания сÑ,оиÑ, свой диодный мосÑ,, но Ñ,ак рабоÑ,аеÑ, намного лучше."
Here is translation
"And now about circuit:
The device has two generators. One generator excites inverter for powering up second generator of nanosecond pulses and powers up main coil. Next - the coils. The coils is winded on plastic core material and contain 3 windings:
First with wire about 0,25-0,3mm (will say exact measurements when I will unwind coils. It is ex-Tesla coil with additional windings added in later experiments). Next coil is on top of first is resonant coil with wire diameter 0,65mm (will call it resonant coil because it has connected only capacitor with capacity 1,5 micro farrads x 400V). Next coil is 50 Ohm coaxial cable (earler it was used as computers network cable) - it becomes bifilar because one end is shorted and second end is connected into generator of nanosecond pulses.  And the last coil on top is secondary for load.
The secondary coil is loaded to diode bridge and after diod bridge there are capacitors (must be unipolar! polar are not lasting long and get broken over few seconds!)
After diode bridge I did connected load of 20W and computer ATX power supply for self running circuit.
But additionally, only one from 4 power supply started to work and it was old AT PS. One did not worked at all and 3 blew up.
The diode bridge between capacitors and secondary coil is a must! Without it there is no stability in working circuit! If somoeone would try to teach me about circuits - I already know about diodes bridge in power suply but wit additional diode bridge it works better."
Good luck!
penno64
Hi Antanas,
May we have a little more info on the grin box ?
Penno
d3x0r
Quote from: Сергей Ð'. on September 14, 2012, 08:42:53 PM
Coil Data:
About Coax. Coax is an original 50 om impedance, old Computer Local Area Network LAN coax. I give a specification for 50 Om RG58, coz it have the same impedance of 50 om, but i am sure you can use 75 om coax from TV sets for the first time experiments.
About 1st coil. The first coil was wounded long time ago and originally was a secundar of Dally's Tesla Coil experiment. Wire is according to him 0,25mm - 0.3mm magnet wire. I think you can use a smaller diameter than 0.25mm. Second coil or resonance coil is 0.65mm. Also i think you can use 0.6 mm as you have done.
And last 4th coil is from special avionic wire. The lenght is shorten coz Dally haven't got a wire for a full winding lenght so he have extended this wire with ordinary electric PVC wire. He was trimmed the lenght and he don't know exactly lenght of load coil. It's between 70-80 turns. This need to be checked but you can make here more turns till the end of plastic PVC water pipe. Put a more windings and later when trimming you always can cut remain of wire. This coils need to be very well isolated coz under this coil is HV coax bifilar coil. Use PTFE for isolation in several layers between coax and this coil. Later when you pump more HV pulses in Coax, isolation need to undergo more than 10kV HV peak nano pulses.  I think you don't need to keep exactly 1:1 specifications, coz this is research project and you always need "FREE SPACE" for your moves. Once when the principle was known and understood to you, you can make evertyhing you want !!
How about that toroid? is that a standard component from something?
