0 Members and 43 Guests are viewing this topic.
Qwert
Quote from: stivep on September 22, 2012, 11:29:40 AM
Please revisit and re-read, article at page 940
Dear Wesley (and others). Please, if you refer to an earlier article in a thread, let us know the "Reply #" or the link to it, since giving just page number is not very convenient: I have set my pages that show only ten (10) posts, so in fact I see the last page number as 1411; regular set is fifty (50) posts, so it's significantly different number.
stivep
Quote from: Qwert on September 22, 2012, 12:39:54 PM
Please revisit and re-read,  my article  at page 940
Reply #14097 on:Today at 09:04:18 AM »
On that page at the bottom there is long article made by stivep  that is me Wesley
The article  is  signed as Wesley at the bottom of it.
I have made major  additions and corrections to it
Please concentrate on electrostatic resonance
Wesley
Ps:  every article made by  me is signed with my name at the end of it.,( if I did not  forget to do  it) :)
jbignes5
Quote from: verpies on September 22, 2012, 12:01:49 PM
Why?
Why because this is exactly what Tesla reported. His later work was with using charged particles and how It would net more in the collision then what it would to accelerate the particle in the first place. Look for the open ended vacuum tube he created.
I'll see if I can get a link for you.
wattsup
@stivep
From what you have discussed, should I understand that a spark gap does not necessarily have to produce a spark to maintain its intended effect?
@all
I need some help understanding the 2004 full wave bridge rectifier. I put an image grab of the rectifier plus a diagram of a standard FWBR as an inset. I would be curious to know where the points of the inset diagram are actually on the 2004 fwbr. Seems to me something is not right there but I could be wrong.
Here is a quote from wiki on Zener diodes. Notice where they mention "Zener and switching diodes are connected in series".
QUOTE
Zener diodes
    Diodes that can be made to conduct backward. This effect, called Zener breakdown, occurs at a precisely defined voltage, allowing the diode to be used as a precision voltage reference. In practical voltage reference circuits, Zener and switching diodes are connected in series and opposite directions to balance the temperature coefficient to near-zero. Some devices labeled as high-voltage Zener diodes are actually avalanche diodes (see above). Two (equivalent) Zeners in series and in reverse order, in the same package, constitute a transient absorber (or Transorb, a registered trademark). The Zener diode is named for Dr. Clarence Melvin Zener of Carnegie Mellon University, inventor of the device.
UNQUOTE
wattsup
stivep
Book mentioned by  many including Arunas
as there is a problem with  access to this  book by many of us I have found one that does not require to give any email or password or  any torrent to have..
just go  and click:
You will be amazed when  you find out that this book at first was say OK to some of
than it is more and more in use and handy because of its simplicity of explanation.
http://www.tuks.nl/pdf/Reference_Material/Steinmetz/CP%20Steinmetz%20-%20Elementary%20Lectures%20on%20Electric%20Discharges,%20Waves%20and%20Impulses,%20and%20Other%20Transients%20-%201911.pdf
Quote from: jbignes5 on September 21, 2012, 10:51:15 PM[/size]
A: did you read the book or not? B: The book is not about free energy it is about waves and how they can and will influence a biased wire. Just go to this link and go to the page I mentioned with the chapter Header: Lecture X
he whole book is a treatise on what the power companies learned over the years about switching the gens on and off from the power lines. What effects shorts to ground have on the lines and the transformers on each end. The resulting waves of both damped and undamped waves are talked about in the book. I would suggest reading the whole book but I guess no one wants to educate themselves. Instead you would rather sit and postulate about subjects you have no clue about. You know how I know you have no clue about them? Because it says no one has really delved into the transients and what effects they have. We know little about this stuff because the transients were always shunted to ground. Which is the only high capacity they could shunt into. Read and learn what the professionals who works on those systems learned by trial and error. The system that TK devised is on par with a Tesla system.
Wesley
