0 Members and 372 Guests are viewing this topic.
forest
Ah Jack..you almost broke my heart  :o I have such coil lying in dust for over 2 years but had no way to power it because I'm dramatically stupid in electronics  >:( and that require at least 600V driver.
captainkt
@Jack Noskills, Hi a few things, inside is a neat oscillator, the 240 volts goes to a solid state rectifier the 240 volts DC is then switched  with mosfet and cap direct to pancake coil that is proper litz wire. When unwound the coil length is 11 metres. Turning over one pancake coil stops induction dead the three I am using all must be just right. Looping back is difficult due to frequency, my circuit runs lots of light bulbs and a 3 kw heater but will not work motors or feed a transformer or inverter. Interestingly the heaters will not run from inverter, not a peep, possibly the inverter needs to be full sine wave. Will try coil underneath this weekend, as I work away.
Keith
Zeitmaschine
Quote from: wattsup on October 10, 2012, 09:02:48 AM
I have not found anything yet on the blue TK inverter. Can't even read the letters even close up. I will have one soon enough. Pure sine wave inverters are not cheap so I am looking for only a 200 watt unit for now.
Is an inverter necessary to run the device at all or is it only necessary to run it in self-sustaining mode (back looped)? Is there an inverter in the 100KW device in the tent presentation? I don't think so. It runs directly from grid, so they compare the input and the output current, but it is not self-sustaining. Therefore what is the difference between 220V/50Hz supplied by an inverter and 220V/50Hz supplied by a matching transformer? It is always potential-free (floating) voltage. This means the device needs a 50Hz reference frequency in order to work, either from an inverter or from grid. It cannot generate its own 50Hz frequency.
I did notice something in the 2004 video however and maybe a few of you can take a look as well. The inverter back plug and more precisely the wire. I think there could be only one wire on that plug.
The plug is still there in the green box video but it is not used. The clamp ammeter in the tin can video shows a steady value during the measurement of the inverter amps output. But in the green box video the value jumps vivid up and down. Hence something is rather different here.
Keeping on thinking ...
