0 Members and 220 Guests are viewing this topic.
e2matrix
Quote from: flathunter on April 17, 2010, 04:26:38 AM
Hi guys.
I know someone here has probably translated or summarised the vids (special russian transformer) that Haltiberlin posted, but just in case it hasnt been, heres my summary
frequency generator at 66 KHz.
12V battery
Special ''crafty'' (or not so crafty :)) transformer made with 2 wires attached to cylindrical copper foil with small section removed (slot).  cylindrical copper surrounded both inside and outside by ferrite beads.  2 plastic ''cheeks'' attached to each end of transformer to seal up the copper.  Then any metal can be used in the hollow core as the secondary of this strange transformer.
Have i missed anything??  some parts were a little difficult for me
Easy transformer to make - i'd like to mess about with one, but i need to buy a frequency generator.
good luck all!
Can you or anyone verify that the part which goes inside the split copper is ferrite?  I've never seen a thin ferrite tube like that (not that I've seen everything :D )  but I'd like to try making this on a larger scale as I've got some large copper pipe around.  The outside rings are also ferrite and not magnets?  I find this strange transformer very fascinating.
forest
Inner tube looks like plastic one. Author of this video also states that it's plastic one.
baroutologos
Ð"енри_Нильский user, has been experimenting all along. Now he claims he found out something of value that he suggests explains Kapanadze device operation.
He already posts into two forums and wants to share. can someone knowledgeable in Russian language and registered @ matrix or lab101 to ask him about a review of what he is up to and see if we can help here also.
thanks
This has been my quote on page before. By monitoring that user's posts and behaviour i think he does not have anything at hand and just speaks out "catchy" terms in the OU society... Lamer i would say.
By the way, in the Lab101 in post http://www.001-lab.com/001lab/index.php?PHPSESSID=596a5ea3130f078133e557eb4053cdb1&topic=4.msg7736#msg7736  an interesting alleged observation was made by toptamburg user.
What i understood from google translation, he claims that a series of ferrite rings, if you apply a strong magnet at one end and remove it. They become temporarily magnetized and then demagnetized normaly. Bu, if you have a winding over ferrites core that is pulses by HV HF, then ferrite properties alter and magnetization becomes permanent to some degree.
He argues this process of altering materials magnetic properties might be the key to Kapanadze alleged device.
Can someone who can read Russian can confirm what i say? (cause translation sucks more or less)
xenomorphlabs
Quote from: baroutologos on April 19, 2010, 03:21:14 AM
That would be somewhat similar to what Floyd Sweet did.
It seems unlikely though because Sweet used 20 KV to condition his magnets (and they were magnets and not unmagnetized ferrites) and
Kapanadze and SR use less (judging from the spark gap and components) and the arcing frequency is not 50 Hz.
I favour the notion of exciting the magnetic domains into a magnetic oscillation stronger than it would be in a normal transformer, because this
is what makes the current.
Omnibus
@baroutologos,
If you’re talking about this quotation:
QuoteавÑ,ор toptamburg Сегодня в 1:18 pm
С Ñ,,ерриÑ,овыми чашками не эксперименÑ,ировал, а воÑ, сÑ,ержневой Ñ,,ерриÑ, превращаеÑ,ся в посÑ,оянный магниÑ, очень легко: подносишь к Ñ,орцу магниÑ,ик и подаÑ'шь на намоÑ,анную на сердечник каÑ,ушку(150 виÑ,ков ПЭЛ-0.35) Ð'Ð' импульсы (импульс). ОсÑ,аÑ,очная намагниченносÑ,ÑŒ явная: чувсÑ,виÑ,ельно приÑ,ягиваеÑ, оÑ,вÑ'Ñ€Ñ,ку (ну.не неодим, конечно, но Ñ,ем не менее) СоÑ...раняеÑ,ся долго-через двое суÑ,ок проверял-есÑ,ÑŒ.Намагниченный Ñ,аким образом Ñ,,ерриÑ, можно вернуÑ,ÑŒ в исÑ...одное сосÑ,ояние (размагниÑ,иÑ,ÑŒ), подав опяÑ,ÑŒ Ð'Ð' импульс на обмоÑ,ку уже не поднося посÑ,оянный магниÑ,ик, или сделаÑ,ÑŒ ему переполюсовку поднеся другой сÑ,ороной. ЭÑ,о проверено лично,пракÑ,ически,неоднокраÑ,но.
Ð'оÑ, поÑ,ом намоÑ,ай двуÑ...Ñ,акÑ,ный авÑ,огенераÑ,ор с индукÑ,ивной ПОС на куске Ñ,,ерриÑ,а... (он как раз будеÑ, подсÑ,раиваÑ,ься в резонанс при разныÑ... сиÑ,уацияÑ...) ... И на эÑ,оÑ, же сердечник еще небольщую каÑ,ушечку - коÑ,орую пусÑ,им на первичку ТÐ'С (никакиÑ... диодов никакой посÑ,оянки) ...ПоÑ,ом сверÑ...у эÑ,ого Ñ,рансÑ,,ормаÑ,ора помесÑ,им индукÑ,ор в виде Ñ,олсÑ,ой медной Ñ,рубки ... И подадим на энÑ,оÑ, индукÑ,ор Ð'Ð' через Ñ...иленький разрядник (индукÑ,ор нужно посÑ,авиÑ,ÑŒ над каÑ,ушкой правильной сÑ,ороной,чÑ,об по Ñ,,азам совпадало с авÑ,огеной) ...
Типа ну и чего мы получили  А получили воÑ, чего - авÑ,огена своей обмоÑ,кой намагничеваеÑ, в нужном направлений Ñ,,ерриÑ, - а Ñ,уÑ, разрядник ТРЯСЬ в индукÑ,ор (с правильным направлением ессно) - и Ñ,,ерриÑ, ХРЕНАСЬ и сÑ,ал магниÑ,ом S-N (при эÑ,ом мы заÑ,раÑ,или на эÑ,о почÑ,и ничего) ..... а Ñ,уÑ, авÑ,огена погнала импульс в другую сÑ,орону - и Ñ,уÑ, разрядник ТРЯСЬ в индюкÑ,ор ..и перемагниÑ,ился МАÐ"НИТИК на N-S ..и Ñ,ак оно циклически smile (разрядов не будеÑ, видно, будеÑ, Ñ,иÑ...ая Ð"УÐ"А..ну Ñ,ак оно на вид выглядиÑ,) ..
И Ñ,уÑ, нам заÑ...оÑ,елось получиÑ,ÑŒ не 500-900кÐ"ц а 50гц .. берем модулируем ТÐ'С (к часÑ,оÑ,е авÑ,огенераÑ,ора подмешиваем 50гц) ... Ñ,.е каждый ТРЯСЬ с разрядника будеÑ, разный по амплиÑ,уде .. На выÑ...оде будеÑ, чудо юдо смаÑ...ивающие на 50гц smile
АÑ... да ! ТуÑ, еще вопрос ? А как же снимаÑ,ÑŒ ? - ну правильно - поверÑ... мы намоÑ,аÑ,ÑŒ не можем, куча вредныÑ... для нас явлений ! .. А надо было склеиÑ,ÑŒ колечки сÑ,олбиком - и на ниÑ... моÑ,аÑ,ÑŒ ..а нагрузку мы снимем по Зацарицински - с его вырожденным ХТ (Ñ,олько воÑ, без Ñ,ого медного виÑ,ка) .. а просÑ,о просунем медяÑ...у поÑ,олще сквозь Ñ,,ерриÑ,Ñ‹ ...
ТуÑ, сразу вопрос ? Ð"де возьмеÑ,ься необÑ...одимое колличесÑ,во свободныÑ... зарядов в медяÑ...е для пиÑ,ания 5кÐ'Ñ,  А земля нам зачем ? (да любой массивный кусок железа, мы же иÑ... будем всего лишь Ñ,уды-сюды пиÑ...аÑ,ÑŒ,насовсем не забираÑ,ÑŒ) ....
ЭÑ,о Капанадзе назвал - авÑ,орезонансом первички и вÑ,орички ..
А знаеÑ,е какое магниÑ,ное поле нужно создаÑ,ÑŒ - чÑ,обы Ñ,,ерриÑ, сÑ,ал магниÑ,ом без дальнейшего воздейсÑ,вия внешнего МП ? - СÑ,ержень диамеÑ,Ñ€ 8мм и длинной в 2см - нужно заÑ,раÑ,иÑ,ÑŒ порядка ~500ваÑ, !!!
А с применением искры нужно всего 1Ð'аÑ,!
Ð'ез 50гц - земля не нужна .. в медяÑ...е Ñ...ваÑ,иÑ, свободныÑ... зарядов чÑ,обы маслаÑ,ÑŒ Ð'Ч ... но нагрузка у Ð'ас будеÑ, максимум лампочки (они с Ð'Ч горяÑ, нормально) ..а для самозапиÑ,ки прийдеÑ,ься выпрямляÑ,ÑŒ Ð'Ч диодами и понижаÑ,ÑŒ ...
Прикол весь в Ñ,ом чÑ,о мы инициируем процесс снаружи Ñ,ора (сÑ,олбик из колечек) - а снимаем нагрузку внуÑ,ри Ñ,ора ... И эÑ,о уже не зацарицын .. мы эÑ,оÑ, виÑ,ок медный выкидываем .. у нас сьемная обмоÑ,ка эÑ,о кабель поÑ,олще просунуÑ,ый между колец ...
Ð'Ñ‹ никак не Ñ...оÑ,иÑ,е приняÑ,ÑŒ Ñ,ого - чÑ,о МП индукÑ,ора и МП авÑ,огенераÑ,орныÑ... омбоÑ,ок = должны быÑ,ÑŒ сÑ,рого синÑ...ронизированы и в одной Ñ,,азе ... Ñ,.е. Ð'заимовлияние ТАМ наобороÑ, обраÑ,ное .. ЭÑ,о Ð'ам и Ñ...оÑ,ел сказаÑ,ÑŒ SR на опыÑ,аÑ... с Ñ,рансами (подаваÑ,ÑŒ Ð'Ð') - воÑ, когда часÑ,оÑ,а разрядника по Ñ,,азе совпадеÑ, Ñ...оÑ,ÑŒ как Ñ,о с часÑ,оÑ,ой Ñ,ранса + доменов Ñ,ранса - воÑ, Ñ,огда и начинаеÑ, лампочка свеÑ,иÑ,ься ярче ...
here’s what @toptamburg says:
QuoteI haven’t experimented with ferrite cups, however, a ferrite rod turns into a permanent magnet quite easy: bring a small magnet to one end and apply HV impulses (pulse) to a coil  (150 windings of ПЭЛ-0.35) wound around the core. The remanent magnetization is evident: tangibly attracts a screw driver (well, not a Neodymium but nevertheless). It’s preserved for a long time â€" I checked it after two days â€" still there. A ferromagnetic material which is magnetized in this way can be returned in its initial state (demagnetized) by again applying a HV impulse to the coil without this time bringing a permanent magnet or by causing a reversal of poles by bringing the magnet to the other end. This has been checked personally, practically, more than once.
OK, then wind on a piece of ferrite a two-step autogenerator with an inductive primary coil (it will readily set itself in resonance in different situations) … also another small coil on this core â€" which we will connect to the primary high-voltage transformer (no diodes, no constant current) … Then, on top of this transformer we’ll place an inductor in the form of a thick copper tube … And we’ll apply HV to that inductor through a meager discharger (inductor should be placed over the coil on the correct side so that it won’t coincide in phase with the autogenerator) …
What did we get … Here’s what we got â€" autogenerator, by its coil, magnetizes the ferrite in the necessary direction â€" and here, the discharger  KA-BOOM into the inductor (with the correct direction, naturally) â€" and the ferrite OOPS has become a S-N magnet (at that we spent almost nothing to achieve it) … now the autogen has chased the impulse in the other direction â€" and here, the discharger KA-BOOM into the inductor … causing the MAGNET to re-magnetize into N-S … and that’s how it goes cyclically (no discharges would be seen, only a silent ARC … well, at least this is how it appears)
And here we’d like to obtain 50 Hz and not 500-900kHz … we take the HV transformer (we att 50Hz to the frequency of the autogenerator) … that is, every KA-BOOM of the discharger will be different in amplitude … At the output there will be a miracle slapping at 50Hz
Oh, well! There’s also one more question how is to utilize this? â€" well, correct â€" we can’t wind on top, a pile of harmful phenomena for us! .. While it’s need that we glue small circles in a column â€" and wind on them .. while we take of  the load by the Zatzarinski method â€" with his degenerate transformer (however, without that copper winding) … and just squeeze a thicker copper through the ferrites.
Here’s an immediate question â€" where can the necessary quantity of free charges be found in copper to supply 5kW. What do we need ground for? (yes, any massive piece of iron; we’ll just push them here and there, won’t take them away forever) …
This Kapanadze called â€" autoresonance of the primary and the secondary …
And, do you know what the magnetic field must be created â€" so that the ferrite becomes a magnet without further application of external magnetic field? A rod of 8mm diameter and 2cm length needs on the order of approx. 500W !!!
And when spark is applied only 1W is needed.
The main idea is that we initiate the process from without the toroid (the column of rings) â€" while we take off the load inside the toroid … And that isn’t Zatzaricin any more … we throw out that copper winding … in our case the role of output coil is taken by that thicker cable squeezed through the rings …
Without 5Hz â€" ground isn’t necessary … there are enough free charges in the copper to spread HF … you’ll have enough lamps as load (they shine normally at HF) … and to make it self-sustaining NF needs to be rectified through diodes and decrease …
You don’t at all want to accept the fact that magnetic field of the inductors and the magnetic field of the autogenerator coils have to be strictly synchronized … that is, the mutual influence in TAM transformer, on the contrary, is the reverse … this is exactly what SR wanted to tell you with his transformer experiment (applying HV) â€" so, when the frequency of the discharger coincides in phase somehow with the frequency of the transformer + the domains of the transformer â€" that’s when the lamp begins to shine brighter.
Good luck.
