0 Members and 477 Guests are viewing this topic.
cheappower2012
@Hoppy, I see by your comments that you think TK is a conman running a smoke and mirrors show.
How in your opinion  did TK fool the Turks given that they had the proper resistive loads,lights, electric motor and they also had the right electronic measuring equipment and electronic experts.
I would recommend Mark Dansie to
go visit TK,Mark Dansie, from hes comments about TK's device ,thinks its a joke,and has the experience
to figure out a fraud and has experts to help carry out correct tests,he shows up on overunity once in a while,he maybe interested.
elementSix
http://www.google.com/url?sa=t&rct=j&q=free+energy+devicethat+use+an+iron+plate+that+used+very+high+voltage+applied+to+it+like+30%2C000+volts&source=web&cd=10&ved=0CGgQFjAJ&url=http%3A%2F%2Fwww.overunity.com%2F7679%2Fselfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze%2Fdlattach%2Fattach%2F113072%2F&ei=n_vGUPSNC8XZ0QGdiICgBA&usg=AFQjCNEgYzv7MU5B-r_Ad5tbaacXIExIng&cad=rja
This is something that was on here somewhere, Its a link to William Mcfreey's description on how NMR is used in Radiant Energy devices like TK's or Steve Mark's.  Everything we talked about, fits all the side effects of TK's device(like RF interference with neighbors electronics, the black Iron powder disks on his work table in the 2004 video that is panned over 2 in the first few moments of it.  Many other things that are a tell tale sign that NMR is the name of the game and I know everyone knows that but I thought there might be some new information in these links about what can be done to achieve it...
http://www.cis.rit.edu/htbooks/nmr/chap-7/chap-7.htm
http://www.measurement.sk/Papers3/andris-2.pdf
http://intro.phys.psu.edu/class/p559/nmr_jdm.pdf
Hoppy
Quote from: cheappower2012 on December 11, 2012, 05:57:56 AM
What test equipment did the Turks use and are the test results available as I've not seen any?
Khwartz
Quote from: sparks on December 07, 2012, 09:11:27 AM
    I just can see the switch animated.  The rest I sort of animate using imagination.  One more analogy would be a transformer.  This would utilize a low velocity high amperage current to produce a high velocity low amperage current.  I am sure we have all seen how an old mill was driven using a water wheel.  (grist mill)  By gearing the massive water wheel  to a high pressure piston pump it is possible to pump water to a heighth well above the mountain top feeding the river turning the water wheel.  The piston pump picksup water from a pond down stream from the mill race and pumps it to a point up stream of the water wheel.  As long as the pond level is maintained at a lower level than the mountaintop lake the system will self-run.  (This would be in practice impossible due to losses in the valving gearing etc.)  Now invision the system and it is raining.  The pond level will remain low as long as no rain bypasses the turbine raceway even though the magnitude of the currents increases.  The piston pump output needs to not return the water upstream but completely out of the system at a rate determined by the rain inches per hour.   Otherwise the pond fills up and the water wheel stops spinning as the system drowns.
Thank you very much for looks tobme, very interesting new analogy, sparks.
Regards, Khwartz.
xenomorphlabs
I can't help to perceive the statement "low velocity high amperage current" as an oxymoron in regards to the current definition I = dQ/dt. But maybe i missed the point here.
You look at an (for some reason) unproportionally high density of charge carriers moving through an area, but doing so with relatively low speed compared to a low charge densitiy moving through an area at a high speed?
