0 Members and 272 Guests are viewing this topic.
grizli
Quote from: yfree on December 10, 2012, 02:59:53 PM
This is not my drawing. I would not call it a "magnetic separator", but axially magnetized gain medium.
The main point is that if it works, it works as described by McFreey.
I cant find information what kind of magnet is that ? how is it made
is there ferritecore inside? any drawing ?
bass
http://www.youtube.com/watch?feature=player_embedded&v=guWga5Q6Dxo
Power supply 220 through a step-down transformer. As I plan to use a current transformer toroidal transformer 220/12, with the winding 220 is closed and only use 12 volt coil.
Efficiency determined by the total power in VoltAmperah (and I think it is right, no matter who said it took into account not only the active power without reactive). Ie this is simply multiplied by an ordinary tester readings taken in volts input and output on the amps input and output.
At Stepanova video output was about 9000 VA and input about 3300 VA. Ie Efficiency in his case, it was 272%. What is written on the "machine" is a 1000% efficiency on the active power that I think is wrong because it does not include the reactive power.
Based on the testimony of a video Stepanova in English, the resonance set is not very exact, because the proportion of reactive power at the input is large enough. Power factor is approximately 1264/3322 = 0.38.
Hoppy
Quote from: forest on December 19, 2012, 04:22:27 AM
There is no point for discussing possible hoax in this thread  >:( If you don't believe TK device is real then fine, but inventing more and more conspiracy theories wouldn't help.
Until a better explanation can be given supported by evidence, I am of the opinion that this is a hoax, not a possible hoax or a conspiracy theory. There is good reason to discuss it on this thread!  >:(
balphom
watts up, you have seen the device working how did they fake that? if we cant make the device does it mean it is a hoax.
27Bubba
Unfortenatuly I'm with wattsup on this one.
If this device was true Tk would allow to take measurements without revealing how the setup works. He would power his house or shop with it... I certainly would.
So in my mind if there is FE to harvest it is not thru TK invention, there must some other way.. 8)
Best..
