0 Members and 91 Guests are viewing this topic.
Hoppy
Quote from: Zeitmaschine on December 21, 2012, 06:00:18 AM
OK, since my equipment is not ready yet, some more theoretical stuff.
According to this very enlightening patent (Сергей В., you're sure this is not Stepanov patent?): METHOD OF PARAMETRIC RESONANCE EXCITATION SWITCH ELECTRICAL OSCILLATIONS AND A DEVICE FOR ITS IMPLEMENTATION
It is all about switching the capacitance (or inductance) in a LC circuit in order to get more energy out than it goes in. The interesting part is that this is done almost the same way as it is done in a Power Factor Correction Device. The main difference in the latter case is that the capacitors are statically switched, whereas in the first case the capacitors are switched dynamically (in dependency of the waveform) by means of thyristors or triacs. The method is called parametric resonance. The resonance frequency in such a circuit changes constantly.
Wikipedia: »Remarkably, if the parameters vary at roughly twice the natural frequency of the oscillator (defined below), the oscillator phase-locks to the parametric variation and absorbs energy at a rate proportional to the energy it already has. Without a compensating energy-loss mechanism provided by beta, the oscillation amplitude grows exponentially. (This phenomenon is called parametric excitation, parametric resonance or parametric pumping.)«
That means if someone plays around with a (thyristor) switchable Power Factor Correction Device (maybe three-phase) then there is a great likelihood that he will discover a parametric resonance effect by chance.
Oddly, on over 1000 page here I can't find the term »parametric resonance« very often, and if I can find it then it is either not explained in depth or its existence is even denied at all.
So we have the Stepanov device with transformers, capacitors and thyristors. We have the Kapanadze devices with transformers, a bank of capacitors (specially designed for power factor correction) and two heat sinks which each can hold a triac (instead of two thyristors), and we have a patent drawing of a device that shows four thyristors and which is described as
»switching method for excitation of parametric resonance and device for its realization by excitation of parametric resonance of electric oscillations by switching method, reactive electric power is generated
And then we have the Steho AG which also claims to have an electric power amplifier based on a resonant transformer (p. 6, in German) and which actually is the Stepanov device.
And then we have the Steven Mark Toroidal Power Unit which looks suspiciously like coils, capacitors and some switching elements. Since the shape of the coil obviously does not matter, it can be anything fancy with a futuristic look.
Now tell me someone that this all is just a (faked) coincidence. >:(
Since the above mentioned patent claims a method for generating electric power by changing the capacitance dynamically in a LC circuit and the TK motor consists obviously of a coil and a capacitor which forms a LC circuit (the two discs are the capacitor plates with the coil between) then what could happen when the capacitance of this capacitor changes somehow dynamically due to its rotation? Could it perhaps generate energy?
Just asking ...
P.S.: Since today the Mayan-Calendar ends (but the world seems to be still there yet), this would be a very good day for someone to tell me that this theory finally works. :)
Lets not jump too quickly into another round of fancy theories before looking at how he might have faked this one. Take a close look at the axle bearing 'bell' housings and think how this device might have been driven from a hidden motor underneath using belts.
verpies
Quote from: Hoppy on December 21, 2012, 07:23:56 AM
Wouldn't it be easier to push on the perimeter of the brass disks with eddy currents?
Appropriately phased coils could be hidden in the thick supports below the pillow blocks (bell housings) or under the bottom of the whole device.
It would explain the 50Hz buzzing sound, too...
dllabarre
Quote from: verpies on December 21, 2012, 06:37:58 AM
Hasn't Wattsup already shown that TK faked his 2004 demo with external power delivery ?
I believe Wattsup only referred to the Green Box video as being faked. NOT the 2004 video.  So far the 2004 video is for real.  so far....  ;D
DonL
bass
 to Zeitmaschine and all
secret of STEHO and Stepanov
Attaching a file with the full description of the principle of resonant power amplifier of Stepanov (STEHO)
you only need to translate into English
This is not thyristors this is diods!!!
verpies
Quote from: dllabarre on December 21, 2012, 08:47:38 AM
Oh. I thought that the TK's 2004 video was the "green box" video.
For future reference, what are the links to both videos ?
P.S.
I am sure that the social psychologists on this forum will write "if TK faked one demo, then he faked them all".
I will refrain from elaborating on this issue as I am more often wrong than correct about psychology and sociology.
