0 Members and 60 Guests are viewing this topic.
NickZ
  Ok, so there were health problems related to the yoke device that lit a 150 watt halogen bulb to possibly 1/2 brightness?  Sounds a bit strange to me. Could this have been used as as excuse, or part of a further coverup, instead of continueing on experimenting to find solutions. It all sound very odd. From save the world, to not doing anything more about it, at all?
  In any case, the ideal situation would be to light bulbs to useable brightness, but without using any man made external input, just earth ground, etz...
  For me, the idea to start a device using solar power, or to maintain it going with that same type of input, would still be considered as a feasible option. Because if using the grid power as input, when it goes out, so will any connected device.
Plus any grid connected device can and does influence the operation on these sensitive circuits.
  The form of tuning the Wesley team yoke is very very similar to Dr. Stiffler's way of tuning his SEC devices.   I don't know who came up with that first, nor does it matter to me. Just noting the similarities,
  Dr. Stiffler has mentioned that his devices do not have any negative harmful outputs, at least no more than a regular Pc, or possibly crt Tv.
  I have been working closely on these yokes for a while now and have nothing to mention as far as negative emissions are concerned, as far as affecting me in a health related way. And the output my yoke puts out is about a strong as Wesleys, as far as I can tell. But, the yokes are in no way similar to the TK much higher output units. The yoke cores experiments, were a disappointment when compared to the much higher output TK devices. And possibly not really that related, as well.
I do find that when the secondary coil's output is feed back to the positive input side, the RF spewing all over the place is decreased considerably. Otherwise most of my devices would be showing Exciter type RF or HV wireless radiations, when running on just a single wire output to the load.
  Any further ideas on these themes are welcome. It seams that most experimenter are just sitting on their hands, lately.
Zeitmaschine
Quote from: cheappower2012 on January 21, 2013, 07:02:18 AM
Not every device is real this one maybe real to a point,in that hes device may produce
some power,but very little,however anything that he has shown could easily be faked wirh batteries.
Here the emphasis should be on »could be«. If we discount all devices as fake just because they »could be« faked then there is a great chance that we will miss some important puzzle pieces from time to time. In Dr. Schwartz's yellow box I can see four (puzzle) pieces of the same heat sinks. And in the schematic of a certain RU patent I can see four thyristors (which most likely need heat sinks). Just another coincidence?
Maybe Dr. Schwartz should use grounding to get more power out. ::)
Quote from: NickZ on January 21, 2013, 10:36:49 AM
Actually I'm trying to get rid of this stupid 6-coil-transformer used in that dizzying RU patent. Perhaps this could lead to something sometime. There has to be a simpler way to connect four thyristors.
Hoppy
Quote from: Zeitmaschine on January 21, 2013, 11:40:56 AM
Getting from 'could be faked' to 'not faked' or 'faked' needs more than just a belief based on wishful thinking. What evidence do you have for the TK devices not being faked?
elementSix
The yoke used in that setup was old soviet made and it had cobalt or magnesium in it.  They were using NMR and when you use certain metals in NMR they can emit radiation, RF signals or both.  If they used something other than a yoke with those metal particles in it, like a nickel, chromium, copper rod or disc they would of had a safer device.  It should work the same, just using different frequencys.
Zeitmaschine
Quote from: Hoppy on January 21, 2013, 12:20:12 PM
The evidence exsists between the lines. If hundred pieces of a jigsaw puzzle fit more and more together then the likelihood that the emerging picture is nevertheless wrong diminishes more and more. Both (fit and wrong) are inversely proportional to each other like frequency and impedance in some electric circuits. :)
