0 Members and 357 Guests are viewing this topic.
zcsaba77
Quote from: ingyenenergiagep on June 19, 2013, 04:06:55 AM
Szia Csaba!
Küldenél nekem róla infót? (Akár privátban is.)
Köszi!
Robert
Udv
Sajna csak annyit tudok rola 30-40 eve probalkoztak, es csak haloztrol ment, es hogy 300% adot le a fogyasztashos kepest, es semmi tobb, hogy ki vagy kik csinaltak, es miert nem sikerult legalabb ilyen cuccot piacra dobni (vagy legalisan terjeszteni, ha mar mashogy nem lehetet  ::))
elementSix
I have been working on my Tesla Magnifying Transmitter and I had a few questions that maybe someone might know more than me.  I have connected a metal cylinder to the top secondary wire that also connects to the top Antenna.  In the Patent, it says this about the connection of the secondary, cylinder and top plate Antenna.
The circuit comprises a secondary coil A which is in close inductive relation with a primary C, and one end of which is connected to a ground-plate E, while its other end is led through a separate secondary self-induction coil B and a metallic cylinder B' to the terminal D. The connection to the latter should always be made at, or near the center, in order to secure a symmetrical distribution of the current, as otherwise, when the frequency is very high and the flow of large volume, the performance of the apparatus might be impaired.
  It says the secondary is led through the second secondary B and the Metal Cylinder.   Does he mean it goes through secondary B, as if it were a tube?  Or is it attached to the secondary B?  I just attached the secondary wire right to the cylinder.  I noticed a  large increase in energy in the circuit.  The cylinder I used was just slotted at the bottom, because its from a vacuum cleaner hose extension pipe.
To prevent the Eddy Currents from arising in the cylinder, should I cut the cylinder all the way up from the bottom?
This is what Tesla Says about the secondary B and the cylinder..
  Still further extending the principles underling my invention, special reference is made to coil B and conductor B'. The latter is in the form of a cylinder with smooth or polished surface of a radius much larger than that of the half spherical elements P P, and widens out at the bottom into a hood H, which should be slotted to avoid loss by eddy currents and the purpose of which will be clear from the foregoing. The coil B is wound on a frame or drum D1 of insulating material, with its turns close together. I have discovered that when so wound the effect of the small radius of curvature of the wire itself is overcome and the coil behaves as a conductor of large radius of curvature, corresponding to that of the drum. This feature is of considerable practical importance and is applicable not only in this special instance, but generally.
Here is a Link to the Patent.  It's not very long, if you were inclined to read it.
http://www.teslauniverse.com/nikola-tesla-patents-1,119,732-transmitting-electrical-energy
P.S.  I have been getting a very good buildup on the Earth side of the Capacitor that is connected to the lower part of the secondary and then connected to the Earth.
elementSix
Here are the Cylinders that Tariel uses in his Red Coil setup in the Transparent Box...  He wrapped the Red one with Copper Ribbon and the Black one he puts a think wire around it..  Could he be using the ribbon for some special properties and possibly use it for a Planar coil..
cltractor
Quote from: elementSix on June 20, 2013, 03:02:34 AM
I noticed the note says the copper ribbon can not be found used, a 2000 year model F250 Ford has about a 3 ft ribbon in the steering column to connect cruise and flashers I have one used lying around the shop.anyone know how many segments it needs to be.
sparks
Quote from: elementSix on June 20, 2013, 01:57:01 AM
  I believe he was talking about the hood being slotted.  I would check with tinselkola on this one.  The whole thing from the end of the coil B is a capacitor curved plate.  This patent instructs one on how to raise the electrostatic energy potential on a curved conductor to it's maximum storage capacity.  The coil of high self induction will determine the amount of inertia in the system.  The terminal will determine the amount of pressure.  The analogy is water hammer in a hydraulic system.  If you have water flowing into an elevated tank  the tank represents a certain amount of capacity.  You fill her up through a control valve and a  long piece of pipe.  If you abruptly stop the flow in the pipe by closing the control valve:  pressure in the supply system rises way above the pump pressure due to the inertia of the water flowing in the pipes on the supply side of the valve.    The water in the overhead tank (static energy) goes kinetic because the inlet pipe suddenly becomes the outlet pipe.   If you have a check valve that takes a long time to close (a large volume swing check) it allows the reverse current to build up in inertia.  Then the valve seats and the pressure in the big pipe (coil of high self induction)  goes sky high again in excess of the head pressure the tank is supplying.  Now the current reverses all on it's own and the tank level rises until the pressure is evenly distributed in the entire secondary.  The control valve is then opened and all it sees is the original head pressure not the water hammer pressure.  This allows more energy into the system until such time as the overhead tank flows over or blows a seam.  This allows the Tesla magnifying transmitter to acquire huge amounts of charge on it's terminal/capacitor that displaces any charges that may be hanging around due to the permittivity of free space. The charges in the space near the Earth's surface are distributed due to the electric field generated by the Earth.  This electrical medium is then excited with displacement waves coming into and out of the Tesla top terminal/capacitor.  In the analogy:  as the tank level rises it displaces air in the tank.  As the tank level lowers air due to atmospheric pressure flows back into the tank.  That is why a Tesla wave is called a scalar wave as it is working with the scalar electric charge distribution found throughout the Universe wherever there is an electric field.
   Hertzian waves are nothing but a bunch of tiny weeny displacement waves created by displacing field charges as we move charge carriers through space.  If you leave the charge carriers alone and circulate currents that move faster than the electrons can respond it is highly more efficient than having to move the little space whirlwinds.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
