0 Members and 84 Guests are viewing this topic.
stivep
To Verpies and rest of us:
Sort this material by  yourself out
  from amusing one to  instructive and constructive  one.
quote:http://www.youtube.com/watch?v=p4-rlmqJ24o
QuoteA NASA funded research project has discovered the existence of unexplained portals between the Earth and the Sun.
the only  what seems to be interesting here is just mechanism of portals
Please leave crap  directed for general public on the side.We  are not interested as much  with that as with our mission,
in astronomy is  characterized this way:
quote:http://www.ireap.umd.edu/~drake/publications/reconnection/phan07.pdf
QuoteMagnetic reconnection drives explosive phenomena in
laboratory and astrophysical plasma. The process is
thought to be initiated in a small diffusion region around
a magnetic X-line, but its consequences are large scale.
Understanding the structure of the diffusion region and its
role in controlling the rate at which magnetic energy is
converted into particle energy
Name of phenomena characterized is:
Electron Diffusion Region
during Fast Magnetic Reconnection
in geophysics
it is explained this way
http://www.spaceplasma.unh.edu/wiki/images/a/a4/Karimabadi2007.pdf
or as :http://prl.aps.org/abstract/PRL/v110/i26/e265004[/size]
Bifurcated Structure of the Electron Diffusion Region in Three-Dimensional Magnetic Reconnection
Quotemagnetic reconnection reveal that the electron diffusion region is composed of two or more current sheets in regimes with weak magnetic shear angles ϕ≲80°. This new morphology is explained by oblique tearing modes which produce flux ropes while simultaneously driving enhanced current at multiple resonance surfaces. This physics persists into the nonlinear regime leading to multiple electron layers embedded within a larger Alfvénic inflow and outflow. Surprisingly, the thickness of these layers and the reconnection rate both remain comparable to two-dimensional models. The parallel electric fields are supported predominantly by the electron pressure tensor and electron inertia, while turbulent dissipation remains small.
2013 American Physical Society
Magnetic reconnection Wikipedia:
http://en.wikipedia.org/wiki/Magnetic_reconnection
Magnetic reconnection is a physical process in highly conducting plasmas in which the magnetic topology is rearranged and magnetic energy is converted to kinetic energy, magnetic field and fast Alfvénic timescales.
Super-Alfve´nic Propagation of Substorm Reconnection Signatures and Poynting Flux
http://www.physics.udel.edu/~shay/papers/ShayM.2011.PRL.107.065001.pdf
the biggest problem we have had is understanding magnetic materials
some of info is in here:
Physics and measurements of magnetic materials
http://arxiv.org/ftp/arxiv/papers/1103/1103.1069.pdf
or
http://www.youtube.com/watch?v=zg8V9XCgIqs
Magnetic field of the steady magnet is non transformable  that means it does not cooperate. it has independence of its own.
But now we are being told that magnetic field can be converted to mass !!!
interesting.
So Simple Colman uses  two electromagnet to disperse beta radiation.. say stop  or slow down process ..
What for? AND HOW?
THE PRIMARY ROLE OF ELECTROMAGNET IS TO CREATE MAGNETIC FIELD AS WELL.
This comment  is intentionally formulated  as below=
Advice from myself to myself:
QuoteInteresting is that one might notice that depends   from  frequency level  beta ,gamma or xray  or neutron radiation  is primary leading one or just singular presence of only one is  noticed.
Frequency of sweep in reality 10MHZ to 500 MHZ but
1. antenna tuner  acting as impedance matching tank did not  tune at all spectrum.
SWR in many of instances was  very high - that means effective power delivered to Colman Tube could be very small.
2. Amplifier was not made to work from 10MHz but from 100MHz to 500M Hz  - it worksomeway OK from 40MHz up.
It was not established  as of yet if presence of radiation elements or just single  one of components is frequency, power or  power and frequency dependent.
What do we have  than more than this there?
Well:
if one could speculate not only  based on instruments but also  based on possible side effects than we might be dealing with proton radiation as well. ( never conformed with available to me instruments)
Side effects might be sort of challenging  to one who was to experimenting with it  if he really wanted .
that might be a moment when  beta, gamma, xray is not present on monitoring  device Neutron is  zero,  but  one might get headache for say 2 weeks ( if right  side of head - no big problem)  If that happened mostly it "may" strike  immediately or with few minutes ( Lithuania Experiment)
if left side of head  than  vertigo or say up/down movement of the image  in front of  eye of one, might happened for period duration of 1-3 seconds - and/or repeatedly for  about 2 weeks.
So one might  use lead box to be OK.
Genitalia must be protected with  lead apron. There might  be at first 5 hours after  that one might feel itch, and than 2 days later  roots of hair - red at first and than  stab ( only on soft  tissue) this might stay for 3-5 days.
It also looks like Lead is solving the problem-AND IS DOING IT RIGHT.
QuoteThe comment is that:
IF WE CAN CONVERT NONRADIOACTIVE MATTER TO UNSTABLE STAGE AND ALSO TRANSMUTATE THAN WE ARE GETTING TOOL TO ALTER MATTER
BUT ALSO THAT MEANS THAT WE CAN COMPOSE MATTER AS WE WISH.
AND REVERSE THE PROCESS
Andrea Rossi is getting copper out of nickel and it is conformed by  number of scientists that cold fusion is possible
So lets be little more speculative.( despite the fact of ones doubt)
Teletransportation?  and  speed travel as form of mass.
duplicating being based on map of that being, constructed during transmutation ( disassembly).
Speed of travel of photon is = speed of light.
So if magnetic field can be converted to mass than  mass can be converted to magnetic field
So if mass can be converted to energy than---  energy can  be converted to mass
So if photon is energy without the mass and than energy can be converted to mass than we talking about speed  of photon and possible  recreation of being or object in   Mars or Moon.( if for that being habitat is created)
But what if we are dealing with  mass to elementary mass conversion and reconversion..
The only difference is speed of mass but travel is possible without spacecraft at all.
How about if Colman is the key to THAT MANIPULATION IN SO PRIMITIVELY SIMPLE WAY.
At first we should see if alchemy that means steady state materials, elements can be created out of map.
How about antigravity?
did not think about it  yet.
But if you think that all of this is simply impossible than recall  Jules Gabriel Verne was a French novelist
Legal note:
1.I do not advice anyone to play with  this technology and  I'm not responsible  for any one trying to play  with it
2.Simple statement  never play with it ever.
3. all of  side effects is my interpretation of what might of happened if it happens at all :) :) But it does not make  any prove of any past or future results admissible in front of court or any legal authorities. PERIOD!! :) :)
4. term: "My interpretation"- is based on my ability to understand,interpret and describe any phenomena and facts and does not make it free of errors. :) :)
5. I was not born with English so that might  be a big difference between  what I understand and what you or anyone understand of what I say  :) :)
6.I use 100% non radioactive components in my  scientific proceeding( experiments) So by that based on official  science It is in direct conflict with physics that n on radioactive matter can be turn into  radioactive one. :)
7. if one wants to legally accuse me on something at first one  must prove that science of physics is wrong- that by itself is a revolution of its own, :) and that will be  official validation of Colman  patent  :)
Note not associated with legal note :
heeeeeeeeeeeeeeeeeeeeeeeeee.= expressional format
THAT WHAT IS BELOW  THE LINE HAS SECONDARY IMPORTANCE OR NO IMPORTANCE AT ALL
if some of you still want to  be amused than   that what below is for you but is NOT RELATED TO OUR  GOAL
1.The Speed of Light Problem
http://www.youtube.com/watch?v=Jx52Z9DrFeY&list=PL2E8142EFAC98A975
The Speed of Light and Relativity Problem: READ THIS before you post comments:
1. If you have the time, please listen to the whole deal first, then think about it (put thoughts into it!) - instead of stopping early and posting high school physics paradigms.
2. The "problem" I am trying to convey is in full awareness of that matter CAN'T nor WILL ever travel at the speed of light.
3. At any times the "problem" is completely independent of that fact.
4. However, in a thought experiment, it is absolutely valid for something WITHOUT mass to travel at the speed of light.
5. Light for example.
6. Described effects (e.g. of "leaving the universe behind") is a logical result of the Einsteinean mathematics. If the mathematics of time, lenght and weight dilation are true, so are the conclusions I am drawing.
The "problem" or "undefined area" it is all about:
- Why does Relativity exist? Why do we observe effects that can be described by the theory of relativity?
- Why is the speed of light exactly 299 792 458m/s? Why do we observe the specific speed of c? Why isn't it different?
- Why is the speed of light finite, if quantum theory proves that in the moment of observation, the distance light traveled collapses immediately (infinitely fast)?
The Answer to all of the questions is given in my other vids - check them out if you can.
electron diffusion region for NASA basic for explanation of existence of time portals in space.
A NASA funded research project has discovered the existence of unexplained portals between the Earth and the Sun. NASA has turned science fiction into science fact by announcing the discovery of hidden 'portals' in Earth's magnetic field.Called X-points or electron diffusion regions, rather than being intergalactic folds in space leading to different galaxies and planets, these portals aid in the transfer of the magnetic field from the Sun to Earth.Essentially, these portals aid in the transfer of tons of magnetically charged particles that flow from the Sun causing the northern and southern lights and geomagnetic storms.'We call them X-points or electron diffusion regions,' said University of Iowa plasma physicist Jack Scudder, who is studying them.'They're places where the magnetic field of Earth connects to the magnetic field of the Sun, creating an uninterrupted path leading from our own planet to the sun's atmosphere 93 million miles away.
What I want from you to  analyze how conversion of electron diffusion region is taking place
As unbelievable as it may sound answer to many of this  questions might be achieved  even few days from  now.( at  theoretical level at first)
use lead box  and everything should be OK
If any  side effects are noticed take 2 weeks  break form experiment
Make note of everything that happened during experiment
Wesley
forest
ok, now  the real source is disclosed  by stivep   ;D  There is no other way to think out the OU process except by Tesla idea realized by many inventors (even before Tesla) like McFarland Cook, C.Amman, Hendershot,Hubbard, Moray,Gray, Steven Mark and so on....
Look carefully Ismael Aviso last video :-) Now I expect Verpies to analyse magnetic reconnection because the same whcih happen on Sun is possible on Earth. In no-scientist slang it is very simple indeed... you squeese in one place and there is a rarefication in nearby (remember Newton III law). Just remember : we are not loading the device ;-) we are using AMBIENT BACKGROUND DISTURBANCE ( Don Smith).
forest
Quote from: forest on July 08, 2013, 05:22:52 AM
btw : to be a little not modest I have adviced theory of operation of it few years ago and even posted it on energeticforum. Tesla was 100% correct about creating sink in magnetic field ;-) you have now almost all required information to go forward
forest
The first point of supression of this technology was Edison etheric force silenced by bankers ;-)
stivep : I think you didn't recognized what you posted, radiation always occure when device is working against the law of nature, it's like trying to play the church organ without any experience....cacophony
stivep
Thank you Forest:)
There is much more into it but I need to rap it up in suitable easy to swallow but "not potentially harmful"  form.
Thank you for your work Forest too.
The bottom line is that Colman could be a key as easy and simple  as impossible, to play with matter and great results - at home.
Micro scale of controllable mutation............... of solids :)
Imagine that it might be possible  by using radio waves...........
Interesting...........
and  magnification of it  is based on energy level.........................
I recall " digits"    9.11.01 interesting  is not ?
Wesley
PS: All of 7 points of Legal Note from my previous post apply.
