0 Members and 42 Guests are viewing this topic.
a.king21
I did a lot of experiments on the Barbosa-Leal  patent and got nowhere. Then recently it dawned on me - Tesla told us a long time ago.
We need HIGH FREQUENCY and/or HIGH VOLTAGE, to get anything out of the earth. It is that simple.
Otherwise the earth absorbs the energy and turns it into.....HEAT!
So redo the Barbosa stuff with high voltage and or high frequency.
captainkt
@a.king21,Hi thanks for that it does make more sense as I also got no where with transformers earth and mains voltages.
Keith
a.king21
Quote from: skywalker66 on October 29, 2013, 07:09:39 AM
@Zeit
Well, a Tesla secondary disturb a lot earths electric field, and it have a HF too, like a radio transmitter, but not modulated with info signal, nevertheless none reported receiving an unusual amplification of energy into tuned circuit. And in that respect was conducted many experiments with tesla stuff.
Maybe if modulate a tesla with a LF (50Hz let say) like the "singing" tesla, receiving within a tuning LC tank and filter HF we'll have something.
Look up stochastic resonance:
https://en.wikipedia.org/wiki/Stochastic_resonance
Hoppy
Quote from: forest on October 29, 2013, 12:39:28 PM
Finally I see so much correct attention. Even Hoppy surprised me  ;D  If you look again at green box video you would see the moment when connection to pipe was terminated while device was still running. That prove iron pipe is only here to dump excess power into ground. The same conclusion could be made from aquabox video , because output is always at maximum level of power and Tariel assistant explains directly that it's impossible to switch big loads at the power station but that device can operate with 40W the same as with 4kW - now you know why.
Hang on there - whoa! Saying that the iron pipe is proof that excess power was being dumped into the ground is simply your opinion as is mine that Kapanadze is faking the whole thing with a external grid or battery based power supply. No conclusion can be reached at this stage.
"......and Tariel assistant explains directly that it's impossible to switch big loads at the power station but that device can operate with 40W the same as with 4kW - now you know why."  And why did the cameraman pan his camera three times and stop to look at the road with the car in centre shot and parked very close to that white wire running from the top of the fence over to a tree in TK's garden.
forest
Hoppy - negative attitude toward the presented by Tariel "experiment" would not let us explain the principle. Most of people who do believe that Tariel is a scam master simply do not post here. Do you have  hidden agenda then ?  ::)
