0 Members and 357 Guests are viewing this topic.
xenomorphlabs
The hungarian replicator has replied to my email and this is what he wrote:
QuoteDear Xenomorph
I'm already a member of the overunity forum. (as Ros-Co.)
The linked page is mine. I tied to collect all of the information about Tariel Kapaladze
The video is about my replication of the generator.  I built it based on the original video, and the "Donalda Smita"  drawing. http://www.hvlabs.hu/zpe/Gruz/kapanadze.jpg
The high voltage stage is different from the drawing.  I used my old TL494 driver
http://www.hvlabs.hu/inverter/inverter2.gif
You can show the whole circuit (in this very ugly drawing) :)
http://www.hvlabs.hu/zpe/Gruz/sajat/Kapanadze_replica.gif
You can show the flyback on the middle top.   The grey capacitor on the bottom right, is the 100nF/5KV.  On the bottom middle there are two rounded 10uF/1,5KV oil capacitors.
In front of the battery, you can show mosfets on the heatsink. The TL494 driver is not finished in the picture then.
Unfortunately, the device can't drive any load.  I tried it with smaller (5W) and bigger (100W) bulbs.  Something is missing....   BUT I found a very interesting effect.  When I touch the frequency control potentiometer (as an antenna)  it causes self frequency modulation.  The sparks are dramatically increased. I think this is one of the key, but it's not enough!
The output coils must be excited with increasing amplitude, to the critical level  (when the energy extraction starts)
Please tell me some information about your research. How can you found me? Do you have any information which helps, step toward?
Farkas Rosko
As he is a member here already, he will hopefully jump into this thread and join forces  :)
Groundloop
Stefan,
I will sure try that. I'm from Norway. We have 50Hz / 230VAC.
Groundloop.
>>Try to wind your transformer according to
>>resonate with external Cap at 50 or 60 Hz.
[EDIT] My small oscillator is not powerful enough. When I tune the coil (with capacitors) then
          the load is so big on the osc. that it "bugs down" and stop. My osc. is approx 1-2
          watt. As I see it I will need at least 10 - 20 watt to have something to play with.
hartiberlin
Hi Farkas,
did you use a real ground wire and try to sync onto the
50 Hz earth currents in resonance ?
jeanna
Quote from: Groundloop on July 05, 2009, 02:27:06 AM
All,
My first try did not work at all so I'm trying a different variant. The high voltage
oscillator was not powerful enough to fire the spark gap. I will make a diode
doubler and rearrange the circuit a little bit. But it looks very nice. LOL
Groundloop.
Hi groundloop,
Yes, it does look nice. I hope it soon works.
In your earlier reply to me you said that the output from the joule thief was pulsed dc.
(I may be not correctly understanding what part of the circuit you are referring to, but I think...)
I think you are referring to the part of the circuit after the first transformer. I am using that too and calling it the secondary.
It is actually the ends of the wires of many turns around the very toroid that produces the joule thief pulses.
I have never been able to capture anything at all in a cap from this secondary unless I used both a full bridge rectifier and 2 more diodes. I collected plenty and watchout for the sparks then!!
Please try this just to see that you have enough voltage.
I bet you do.
I believe this is the reason for the diode in the fuji ciruits, too.
If I am talking about a different part of your circuit, then
my apologies,
jeanna
Groundloop
Jenna,
I was not talking about Joule Thief in general.
I was referring to the posted drawing.
The pulsed DC is after the diode.
Thanks for the correction. I should have stated that I was describing the posted
circuit and how a spark gap works.
Groundloop.
