0 Members and 371 Guests are viewing this topic.
zcsaba77
Quote from: captainkt on May 19, 2014, 06:43:47 AM
@hoppy, at least he disconnects the earth and the device stops, no one else has done that. The wire cannot be a power feed as he touches it several times without getting a shock. Also reconnects earth then has to re start.
Keith
Hi Keith
Just one weird thing, I know until in Sovjet Union and now post Sovjet Union stats phase was not grounded with earth (you can touch each connection, BUT not at once, and not was shocked), someone can me explain how is possible mr vasmus how lit the bulb with phase and the real ground? or one phase is grounded now in these stats?
regards zcsaba77
leo48
QuoteLeo
This linked to toys!?
I do not know this message appeared in my recording youtube and I can not understand the link .....
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
zcsaba77
Quote from: Hoppy on May 19, 2014, 03:48:13 AM
Wesley,
A jumble of wires and components is meaningless and IMO a waste of your valuable time trying to explain it all. This guy has already posted a couple of previous videos showing the same unconvincing setups with so called ground wire disappearing into nowhere.
I little bit must agree with Hoppy and Wesley too. Some of these coils look weird, (criss-cross winded trans or coil in carton box on left bottom, standing coil is HF/HV (probably) transmitting part, but these lieing coils side by side (one look like not connected to nothing) real function? receveing!? step-down transformer? these coils is air/ferrit corred?
With Wesley agree with this once activating things, I have trouble with moisture walls, my friend offered me dry by power, like this: from grid to isolation transformer 1:1 use diode or d. bridge negative pole to place where from want pull water, to positive (beetween positive and bridge need bulb in begining 100w later change to smaller, depend on moisture in wall), and in information was one weird things (unexplainable mainly for me) after 1 year useing possible disconnect from grind and just connect positive and negative, and will flow electron itself!
zcsaba77
Quote from: leo48 on May 20, 2014, 04:49:00 AM
Leo48
this is your video?  :o
what was original?
captainkt
@zcsaba77, Hi your post is interesting in that if Russian grid is not grounded as in the UK then to fake device to earth using hidden grid wire would be impossible. Two wires would be required and then not to Earth. I mess with live wires when experimenting and even if as Hoppy said it might be HV/HF a shock is hard to hide unless camera trickery was used.
Keith
