0 Members and 42 Guests are viewing this topic.
Hoppy
Are the blue cables in these two photo clips from the Aqua2 and green box videos the same type?
captainkt
Hi Hoppy, the green box blue wires are silicon HT from motor vehicles ignition/spark plugs 100%. The aquariam wires look to be plastic covered so I would say not exactly the same.
Keith
Hoppy
Quote from: captainkt on February 16, 2016, 07:00:14 AM
Keith
Hi Captain,
Its not easy to tell, as the aqua2 grenade coil is covered in a plastic poly wrap. In post 22164 Cheappower2012 shows the blue cable terminated to the green 3-phase transformer and it appears to me that it may have two thin conductors like the spark gap cable. The reason I'm asking, is that I have assumed in the past that the aqua2 cable is likely a co-ax with the outer sheath removed. If it is not, then given what TK stressed about the importance of getting hold of co-ax cable to complete the aqua2 device for video presentation to a.king21's team, then maybe he was referring to the earth braid. If that's the case, then why was it so important to use copper braiding for the earth wire, rather than a length of ordinary welding cable or similar, like used for the green box device??
captainkt
Hi Hoppy, I think he just uses what he can get hold of at the time.
Keith
cheappower2012
People don't get just how devious Tariel is,he says things untrue because he knows that people will focus on them,there red herrings.I can't get a certain this or that,people grab and run with it.Tariel and SM inventor of the tpu think the same,fake out people looking to replicate there devices.
The kapanadze device has nothing to do with Tesla,he says it does so people will focus on Tesla.Hoppy's approach is  correct, if a device is a possible fake ,can I show it could be,you don't want to spend time investigating a fraud believing its real thats madness.However  you have to be very careful that you don't declare a device as fake, but it really maybe real.The picture very much sums up how complicated figuring out Tariels device is,without a core concept.From a logical stand point the blue coil is simply that a long coil wound in different directions,an air core,a current must flow between the ground and the end of the coil,to a load(heater).At least 9 amps must flow to light the heater,the coil has very little inductance,winding it in different directions  causes the effective inductance to be less than a simply wound coil.The other end of the coil connects to the 3 phase transformer with a resistance of 78 ohms,from a logical standpoint it must therefor be a fake,since its impossible that it could work.To make Hoppys theory correct you would have a small wire shorting the transformer connection where the blue wire connects.A wire goes to this connection hidden,in back of the transformer this wire then connects to the bundle of wires,this then goes to the back connecting to the long out side cable,and the mysteries
solved.You can see that this is a very hard problem,this is why the giant brains,more or less gave up.Keep in mine I believe its real and uses principles very different from how I was taught in college very hard to
figured out, both the tpu ,not all are real,and kapanadze's devices operate in similar ways.
