0 Members and 332 Guests are viewing this topic.
Goat
Quote from: flathunter on June 18, 2010, 04:33:08 PM
Kapagen for the poor man:
@ flathunter
Please keep the photo size under 500 pixels otherwise it messes up the page and people have to scroll left to right in order to read the text.
@ Admin or Moderators
Can there be a photo size limit put in place so that people are made to resize the photos when uploading?
Edit: Stefan, why is it that when you write the text is kept within regular page width but when other users post the text defaults to the size of the over sized image.
Regards,
Paul
hartiberlin
I resized his picture to 800x600.
Please ALL keep your pictures at 800x600
this is enough detail, if you take a clear picture.
Many thanks.
woopy
Hi all
this post is very important to my eyes
concerning the winding  and to avoid confusion and to be sure to replicate correctly
i updated the drawing
winding A    = the main coil goes from right to left until the the end of the plastic tubing (about 84 turns ), than goes back  (about 22 turns ) without changing the winding  direction as per a normal solenoid                      The big coil  (heavy wire and big diameter about 6 turns ) is also in serie as per a normal solenoid , and goes to the load.
                    critics of this winding by Ossie Callanan  ( so far i have understood) he does not see the interest of this winding as there is sinply a normal solenoid coiling  without punching possibilities.
winding B    = the main coil goes from right to left until the end of the plastic tubing, than you reverse the winding direction, that is to say that you stop the direction of winding and wound back to the SG.
                    you do the same with  with the big coil.
                     After the notice of Ossie , i relooked at JLN pix and i am sure that for the big coil it is that winding  (B winding) but i can not see what is the winding for the left parts. i mean A or B
                    than i asked to every body and romerouk answered that  he would recommend Windind  B of the drawing.
Winding C  = the main coil goes from right to left until the end of the plastic tubing,  than as per winding A simply continuing winding as per normal solenoid until the SG.
                   but the Big coil stays as per winding B
                    So far i see as per JLN last shematic (thanks to JLN) it is very brobably the winding C that he uses.
and the winner is ?
regards
Laurent
tadejstenta
hartiberlin
based on my experience, i can tell you:
- my coil winding ("b scheme") does not matter if i connect it with or without 22 coil - same behavior and same amp draw and light brightness;  also doesn't change nothing if i connect in system only 81 coil winding (without 22 and 7 turns coil) so i assume, that "coil effect" ( i don't now how to call it) doesn't work in my case
- in the center of the coil i was putting : single wire, single wire with multiple strand wires (different matterials), combinations with wires and cooper tube (wires beside it or in it), wires slowly putting in and out during the operation, also the ferrite rod putting in and out; nothing of above worked ( no significant changes)
- when i had connect the third ground line to MOT i saw no changes, i put MOT directly on the ground - grass and nothing changes, but i noticed, i had to have At east two ground - that is when i disconnect one, system stop
also noticed, when the one of wire to the ground is only in one side connect to system and at another side is just laying in grass than system runs, but amp draw increase
- when lightbulbs are connected in series they are brighter as in combination with parallel
-i had  sparkquenched  the sparkgap and spark began different colors and much more violent and loud, but no changes in amp draw
- only thing that does change amp draw was when i played with cap valuse ( all MO cap) - cap in series, parallel - combined,..
i noticed when amp draw rises lights get brighter ( 3.5A and lights are Little over half brightness) and when amp decries also decries brightness of light ( 1.3 A and light is about 10 %)
from all above i think my coil is not functional as it should be, i also change big coil (replaced with 7 turns of multistrand wire cca 4mm from welding machine) - no changes
any suggestions ( not have scope or any other hi tech apparatus  :'( )
regards,
tadej
jermutin
Hi all,
I'm new in this forum. :)
I have been anxiously following this thread and JLN labs progress. It all just seems to be going forward so well. I've also started to gather some things for my own replication..
But I have to ask about a comment posted right in the beginning of this thread.
QuoteOmnibus wrote:
Kapanadze has managed to use the energy of the existing 50Hz lines for electrical energy transfer (LET)....
...attached to the resonance circuit, tuned at 50Hz, we obtain a simple "robber". Its functioning is similar to a receiver of direct amplification, let alone the method is efficient enough under high-voltage line (HL) 110-220kV ...
The schematic presented is used in Ukraine. It's placed in the clearing alongside the LET of 500kV (in a forest area).
And this really set me thinking, that could it be possible, that all those Watts are being robbed (accidentally) from the house grid / other system nearby.
I'm not meaning to be a naysayer, but one has to ask these things.
I would really like to see someone using the Kapagen with a diesel-powered portable PSU in an area where theres no possibility for the power to be coming from another grid..
But, I truly hope that the excess power is being craved from "the wheelwork of the nature"..
-J
