0 Members and 586 Guests are viewing this topic.
exnihiloest
Quote from: hartiberlin on June 26, 2010, 11:47:56 AM
The digital Wattmeter should be put in FRONT of the variac directly at the house and
NOT in the garden, so the extension cord should already dampen any RF noise on it
and the extension cable should be put through a toroidal ferrite core to filter out the
RF noise...working as somekind of lowpassfilter which blocks all RF noise.
All the device is inside, not in the garden. Nevertheless the noise would be surely reduced if the measurement is done in front of the variac, and after adding an HF filter (I have several). I will try.
This way the output power could just be measured as a simple DC power measurement
by multiplying voltage x current.
I'm not sure to understand your method. For me, it can measure only peak voltages and currents, neither rms nor power.
And even if we measured rms, we can't do the product of rms values to get the power, because the product of rms values is not equal to the rms value of the product (for ex. when U and I are 100% out of phase, U and I are not null even when converted to DC, nonetheless the power is zero).
This then would also be easier to convert it back via an inverter to the AC input power
to loop the device in a selfrunning mode.
It is the ideal case. But we need to get much more output than input to compensate the losses of the conversions AC/DC DC/AC.
This has to be confirmed, but I "feel" that the output power is of same order as the input power.
exnihiloest
http://www.youtube.com/watch?v=2pywtoyNEcE&feature=player_embedded
Still the same problem: the mesuring device is not intended to measure a no sinusoidal current with high frequencies components. With only a few watts from my HF transceiver I can greatly disturb any of such devices and let them display whatsoever.
grizli
Quote from: IWD on June 26, 2010, 12:44:48 PM
That is also the same, what Eric Dollard show in video tesla longitudinal electricity, which has ben already posted.
http://video.google.com/videoplay?docid=-6461713170757457294#
on 13:00 minuts
Its not quite the same ... but similar
MorePowerEgor
Simple solution....
Moving coil/iron ammeter and volt meter in primary.
or run the thing from a small petrol generator. Connect a load up to the point where the breaker trips, then short it out.  Now connect the Kapgen and run it and see if the generator stalls or grunts.
Say you have a 3kw generator running a known 3Kw load,  and you can hang an additional 10*150W halogens on its ass without it complaining,  then it's a fair bet that the apparent 200W demand is true.
A generator does not get confused by RF.  It's just seeing a demand for physical energy - joules!
Acca
Here is the video link to the KapaGen, that the photos represent in my previous post, there is no audio because it was recorded in hi speed 210 frames per second video. http://www.youtube.com/watch?v=x6wVwYYZqeg
P.S. I have just uploaded the video to my "magnetflipper" channel on YouTube, it may take a while for it to spread across the net.
