0 Members and 519 Guests are viewing this topic.
Dankie1
Quote from: dole on July 22, 2010, 07:56:01 PM
Hi,
Please forget Philadelphia “cheesecake” we are not there yet, I would appreciate some help. Does anybody know good and simple schematic or way of getting (buying)  100% sinusoidal variable freq generator up to 20 000 Hz and output around 300W?
Please this is what I found and it could be totally wrong. I think resonance must be fulfilled in the wired itself first i.e. induction capacity and frequency and further I think this is not coincident that Kapanadze use coaxial cable. I suggest those who still experiment to look in to coaxial cable properties, induction capacity and frequency (I think ferrite may magnify this later) probably this is what Don S. is using or primary. I guess Tesla wound this to, documented as twisted pair but in reality one with twisted shied around enlarged later and called Caduceus coil (It is believed that will generate scalar waves).
Thanks
d.
This is not ground cable !!??
http://www.ionizationx.com/index.php/topic,1404.msg16396/topicseen.html#msg16396
I will soon be releasing my product after 1 year in the making , my amp does not suffer from what I call transcients  dirty current , current and voltage stay sinusoidal always . All the oscillators you will ever need will be on the board , amps included . freq up to 25 khz
The amp works well for dioded circuit after all , and can be modified in a flash for fully class a push pull .
I designed primarily for clean current and clean voltage and for durability , efficiency is about 60% with my design , less with push pull .
nievesoliveras
Quote from: gyulasun on July 27, 2010, 05:17:41 PM
Jesus,
There is a dedicated link directly to Mr Kundel's "tinkerings", all in English:
http://www.kundelmagnetics.com/
Gyula
Thank you @gyulasun
dole
Quote from: Dankie1 on July 27, 2010, 05:40:09 PM
I also made a kapanadze oscillator for my kapanadze experiments , it works real nice actually  , those circuits posted by the russian guy work  , modified it a bit , Im gonna draw it up and post it on energeticforums . Its basicly a simple 4 component add-on to my EEC P mosfet design , now isntt that great ? You see how things add up easily when the HHO God is on your side . I was gonna take out my Stan pulse to save space but it looks like it will have a use after all .
Thanks, interesting, may you post some more information here or may not?
d.
ramset
Dankula
________________________________
Perhaps that could be used here?
5 watts 5 minutes 1 gallon of water to gas!]
A real "game changer"!!
http://www.overunity.com/index.php?topic=9448.135
Nice to see your still at it!
Chet
Thanks Grandma
Dankie1
This circuit was posted at energeticforum.com on the sr193 thread , circuit from russia .
I believe this is doing whats its supposed to do .
My only modification is that I use a mosfet for the switch , he uses a pnp , I dont like transistors for switches .
***Photo size edited by Moderator***
