0 Members and 46 Guests are viewing this topic.
cosmoLV
Quote from: Dankie1 on October 08, 2010, 12:04:53 AM
Cosmos , what frequency range are we talking about here .
Carrier and modulator .
What about the low frequency signal , is this a sine or square signal .
dole , plz send me your books .
i do not have a oscilloscope to measure frequencies, but something about 25kHz to 21MHz
QuoteWhat about the low frequency signal , is this a sine or square signal .
used are both
for experiments i use square for Low side - but in final stage i use square for HV and sine for Low side - but way how this is done, i keep for some time in secret.
Offtopic:
little joke, they are now zombies? seems it is bad for health  :)
Keep your chakras opened :)
cosmoLV
if you have anaglyph glases Red-Green (red on left side)
there can bee seen interesting things how are connected bobbins with TeslaCoils ;)
Dankie1
Quote from: cosmoLV on October 08, 2010, 12:28:13 AM
used are both
Offtopic:
There is  big difference between 20 mhz and 25 khz in building complexity , even for square oscillator . I did not expect things to vary 1000 fold , plz be more specific . But it can be done , thx god this is not a sine oscillators as variable sines of this broad range is very big circuit .
What about the modulated signal , this is the frequency of the lowm side correct , or a harmonic of it ?
cosmoLV
This is the one of most closest - just try to polish it and you understand whats going on there (the center tap of caps are not connected to GND this is feedback of synchronisation)
baroutologos
Quote from: cosmoLV on October 07, 2010, 09:59:07 PM
The transistors are go wild because it not worked synchronous with Sparkgap (you do not get on it? you really think that in SR setup transistors are modulated with 50 Hz?) No - i just say no, because this not worked for me in any way, for experiments 50Hz ok, but not for real selfruning device... :)
The convention and obsession of using 50Hz is the desire for people to extract ready useful electricity o power up their household appliances. Other than that 50Hz is an arbitrary frquency and very low for anything of value.
My question was not about the syncronisation. Was about the heavy RF currents that any working spark-gap creates and derates any timing device as a 555 circuit, making difficult if not impossible to see a concept.
You said for experimental purposes and for becoming the effect obvious to the eye, a DC current could be applied or a even 50Hz outputed from an transformer to ferrites (LV winidng).
The HV supposed winding will nulify core's electromagnet properties.
This experiment works or not? So far no possitive indication on that i can say.
