0 Members and 357 Guests are viewing this topic.
cosmoLV
Quote from: LtBolo on October 15, 2010, 03:19:38 PM
Posted in this thread forever ago...
http://www.overunity.com/index.php?topic=7679.msg189076#msg189076
It has nothing to do with free energy!
by The Way: Eric Dollard has big respect in my eyes â€" someone has posted some link to his works, thanks :) There are Youtube also:
http://www.youtube.com/watch?v=YhuSn6sc7sc â€" the longitudinal waves what about Dollard and Tesla speak are in ground wire in kapanadze device, and two potentials are making these waves. there are only one way how to make longitudinal waves appear..
Keep your chakras opened :)
nievesoliveras
If you want to see the coil on the captured picture explained, check the linked videos on this post:
http://www.overunity.com/index.php?topic=9688.msg255297#msg255297
Jesus
baroutologos
Quote from: cosmoLV on October 15, 2010, 06:50:14 PM
Hey Cosmo, I have a question that haunts me a lot regarding Kapanadze Green Box unit (and other as well). Kapanadze apart from his secret built devices, demonstrates that a ground wire is needed (the better ground the larger the output) and also, this thick usually wire bears considerable amperage. (it shows it with an amp-clamp meter)
How is this possible? I have read and built Tesla coils and i am familiar with their mode of operation.
In order to achieve some 20 amps current between a SINGLE ground wire and the DEVICE, assuming its unconnected to any further ground (only to loads) then this cannot happen.
In other words, in order to have such large amperage between a device and ground It would required an enormous one-terminal capacity and a vast working voltage.
Not to mention that in order a conventional clamp meter to work it would require more or less low frequency (fact that boosts further working voltage and single-terminal capacity)
What you say about that?
cosmoLV
Quote from: baroutologos on October 16, 2010, 06:22:58 AM
imagine a mop as kapanadze transformer, two potentials who squeeze third coil who are in middle and ground wire into middle of that transformer.
when you squeeze it, then all air is out, when you take off hand then mop bring back it's position where all air fill it again without help from the side..
baroutologos
nice analogy and potential explaination. So far no-one has tried to give any plausible answer, i far i remember..
But, down to earth terms, how you can sqeeze a bunch of wires (hence a coil) and expel all its electrons to ground? At best in case you employ a capacitative approach (what else?), the current would be minute.
(it would be the product of single terminal capacitance x voltage applied x frequency)
Any thoughts you can share?
